How can a person make a zoom window in VBA. In this case I would like to pick
two points on the screen to zoom window to. I would like for may vba program
to store the picked points for future use.
Thank you,
I have tryed this code but I am having problems with command send
Me.hide
pt1 = ThisDrawing.Utility.GetPoint(, vbCr & "Select Point 1: ")
pt2 = ThisDrawing.Utility.GetPoint(, vbCr & "Select Point 2: ")
'ThisDrawing.WindowState
ThisDrawing.SendCommand ("zoom" & vbCr & "w" & pt1 & pt2)
Me.Show
I know nothing of VBA, but I know there is a method ZoomWindow in LISP - may apply to VBA...
Here's my guess... and I have never written a thing in VBA...
ThisDrawing.ZoomWindow(pt1,pt2)
:lol:
  • 2 years later...
This code works with AutoCad 2007
y1$ = pt1(0): x1$ = pt1(1)
y2$ = pt2(0): x2$ = pt2(1)
ThisDrawing.SendCommand "zoom" & vbCr & "window" & vbCr & y1$ & "," & x1$ & vbCr & y2$ & "," & x2$ & vbCr
John
cor, an old thead!
To put Lee's mind at rest, this works.....
Public Sub aTest()
Dim myPoint1 As Variant
Dim myPoint2 As Variant
myPoint1 = ThisDrawing.Utility.GetPoint(, "BL Corner")
myPoint2 = ThisDrawing.Utility.GetPoint(, "TR Corner")
ZoomWindow myPoint1, myPoint2
End Sub
Hello
I found this thread while trying to write code for the zoom command event in Autocad. I want to redraw the labels on a graph, with the text size and placement dependent on the display extents as compared to the drawing extents. Here is the event driven code (not finished yet)
Private Sub AcadDocument_EndCommand(ByVal CommandName As String)
'ZOOMED
If StrComp(CommandName, "Zoom", vbTextCompare) = 0 Then
'get display extents
'view center in WCS
ctr = ThisDrawing.GetVariable("VIEWCTR")
'convert in to DCS
ctr = ThisDrawing.Utility.TranslateCoordinates(ctr, acWorld, acDisplayDCS, 0)
'height of the viewport in DCS
h = ThisDrawing.GetVariable("VIEWSIZE")
minp = ctr: maxp = ctr
'calculate the width of the viewport in DCS
vph = ThisDrawing.ActiveViewport.Height
vpw = ThisDrawing.ActiveViewport.Width
w = vpw * h / vph
'calculate bounding view boundary in DCS
minp(0) = ctr(0) - w / 2
maxp(0) = ctr(0) + w / 2
minp(1) = ctr(1) - h / 2
maxp(1) = ctr(1) + h / 2
'show that the points are indeed the ones we are looking for
minp = ThisDrawing.Utility.TranslateCoordinates(minp, acDisplayDCS, acWorld, 0)
maxp = ThisDrawing.Utility.TranslateCoordinates(maxp, acDisplayDCS, acWorld, 0)
ThisDrawing.ModelSpace.AddLine minp, maxp
MsgBox ("Zoom command finished")
End If
End Sub
When SendCommand is used to zoom, the event routine works, when ZoomWindow is used, the event routine is not called, although the zoom window happens. I'd like to get rid of SendCommand.
Thank you
John
