Hey there all,
wondering if you guys have had this problem and know the answer if there is one ??:?
In one of our drawings here at work, there seems to be a bug making me not able to select certain bits of text, it has happened before where it was like 5 different bits of mtext and even some lines etc, and to get around it i opened a new drawing copied my drawing in to it and rewrote the text and redrew the lines etc etc, and never had the problem again. but noway am i wanting to do that again as i don't have the time (although if worst comes worse and it's my only outcome i will do it)
when i select all (ctrl A) it selects the bits i couldn't before, but then when i press escape and then try to select the text in question ........Nothing. it's as though they are part of the black background. i try the move command, erase command and still does nothing the text is stuck there
a few things to work with:
1. the text/lines are not on defpoints
2. are not locked
3 are not masked.
any help would be fantastic
Cheers
Emily:shock:
  • 3 weeks later...
have you tried select all and then wblock it to a new dwg and explode there?
Emily,
Any chance the text is an x-ref?
Have you tried simply editing the text (change a word, add an number, etc.)? Will it let you do that? If not, it may be part of a block that you're not seeing all of due to the zoom level or something. If you can edit the text, then you got something really hinkey going on.
