astitchintimesaves9 Posted May 20, 2009 Posted May 20, 2009 I found this answer to the 'flatten 3d drawings to 2d' problem (re 2007 LT)... This sequence of commands flattens many objects: Move All 0,0,0 0,0,1e99 move p 0,0,0 0,0,-1e99 but this does nasty things in my Autocad 2009 so I changed it to.... Move All 0,0,0 0,0,1e99 move all 0,0,1e99 0,0,0 which seems to work. I did this on a hunch, will it create any problems? Quote
ReMark Posted May 20, 2009 Posted May 20, 2009 I don't understand why you wouldn't use AutoCAD 2009's own Flatten command. Is there a good reason? Quote
astitchintimesaves9 Posted May 20, 2009 Author Posted May 20, 2009 Because I get an 'unknown command' message. Quote
ReMark Posted May 20, 2009 Posted May 20, 2009 I'm running 2009 right this very moment and checked it on my system. The command works fine. Maybe you mis-typed it. Quote
ReMark Posted May 20, 2009 Posted May 20, 2009 Since it is accessed via the command line and you don't seem to have it then I must assume you did not load Express Tools when you installed AutoCAD 2009. Am I correct? Quote
astitchintimesaves9 Posted May 20, 2009 Author Posted May 20, 2009 I didn't install it, but yes, I think that's what happened. Quote
ReMark Posted May 20, 2009 Posted May 20, 2009 You can still install Express Tools by reinserting your installation disk. I believe it is a listed option. You paid for AutoCAD so take full advantage of everything it has to offer. There are some real gems in ET. Now, go find them. Quote
astitchintimesaves9 Posted May 20, 2009 Author Posted May 20, 2009 OK but going back to my original question, will that method cause problems? Quote
ReMark Posted May 20, 2009 Posted May 20, 2009 It shouldn't. You can also try the FLATSHOT command. Quote
astitchintimesaves9 Posted May 20, 2009 Author Posted May 20, 2009 tnx, the draftie that oversees the acad stuff has it on his computer but no one else does......i suspect that he'll be 'too busy' to sort out the disc but i'll try. Quote
ReMark Posted May 20, 2009 Posted May 20, 2009 Then try FLATSHOT. It's included in the solids editting commands. Quote
f700es Posted May 20, 2009 Posted May 20, 2009 I like FLATSHOT too. It does not destroy the items like FLATTEN does (unless you copy it 1st). I have gotten great results with FLATSHOT. Quote
Fernandobtn Posted December 29, 2010 Posted December 29, 2010 nice!!! how did you came up with that? what does the 'e' on 1e99 means? Quote
ReMark Posted December 29, 2010 Posted December 29, 2010 How? Either someone taught him that trick, he learned of it completely by accident or he read it somewhere (a book, magazine or on the Internet). The 'e' is engineering notation. As quoted from Wikipedia: Engineering notation, as used in civil and mechanical engineering (United States), uses the following notation where: 3.0 × 10−9 can be written as 3.0E−9 or 3.0e−9 Quote
Fernandobtn Posted December 29, 2010 Posted December 29, 2010 did YOU knew this engeneering notation before? or did you searched the web for the meaning of 'e'? That seams like a dificult search! Any ways, thanks. Quote
ReMark Posted December 29, 2010 Posted December 29, 2010 I was familiar with the term so the searching part was not difficult at all. You're entirely welcomed. Quote
astitchintimesaves9 Posted January 4, 2011 Author Posted January 4, 2011 No, like I said, a hunch (or inspired guess?). I saw what was being used and had a stab at adapting it. I went from forum to acad without referencing other sources, and it worked. Sometimes it has difficulty with blocks but this can be overcome by exploding them before flattening. How? Either someone taught him that trick, he learned of it completely by accident or he read it somewhere (a book, magazine or on the Internet). The 'e' is engineering notation. As quoted from Wikipedia: Engineering notation, as used in civil and mechanical engineering (United States), uses the following notation where: 3.0 × 10−9 can be written as 3.0E−9 or 3.0e−9 Quote
