streng Posted May 20, 2009 Posted May 20, 2009 Hi I have created a modeless userform that stays above all windows. Unfortunately when the userform is selected or used it reopens the window its associated to. (ie AutoCAD) In there a way to disassociate this from AutoCAD, or associate this to Excel. I know API is involved but I have no knowledge of this. Have attached file in case this is vague. Hope someone can help. Userform on Top.zip Quote
rocheey Posted May 20, 2009 Posted May 20, 2009 Thats just part of the deal, unfortunately. VBA is running -inside- of acad. It is basically a child of autocad. if you minimize autocad, your form goes with it. if you activate/ restore Autocad, your form returns. If you want both, you'll want your routine to run outside of autocad, to boot - probably a compiled VB app. Quote
