VVA Posted October 27, 2009 Posted October 27, 2009 To build complex reports easy to use commands _EATTEXT and/or _DATAEXTRACTION. I propose the following method: 1. To select objects inside the polyline command using SCCP or SCWP These commands add selectted objects to prevoius set. 2. Use _EATTEXT or _DATAEXTRACTION. 3. In Data Source use "Select objects" and at the prpmpt "Select objects" use option _P (previous) PS if you lay out a small example, perhaps I can help, and a specially written program Quote
