Hi All
I am trying the use the ssget to select a vp then command mview & mspace then vplayer to freeze & Thaw layers depending on the layoutname.
heres what i have
(setq GAVP (ssget "X" (list (cons 0 "VIEWPORT")(cons 410 LAYOUTNAME)(cons 62 1))))
(command "mview" "on" GAVP "")
(command "mspace")
(command "vplayer" "f" "**" "a" "t" *0?RYD-GA-700*,*GN-COLS*,*" "a" "f" CONZONE2 "a" "")
(command "pspace")
Problem is all the paperspace layers are being frozen with the vplayer command, even though i am in mspace not sure what im doing wrong. Can anyone please advise?
It freezes all of them because you are telling it to.
try this
(command "vplayer" "f" "**" "c" "t" *0?RYD-GA-700*,*GN-COLS*,*" "c" "f" CONZONE2 "c" "")
Sorry for being so short in my last post. Quite simply you were choosing "a" for all viewports instead of "c" for Current viewport. And as we all know paper space is considered a viewport therefor freezing the layers inside it.
Ah!
I didnt know that all mean paperspace as well, i assumed it meant all viewports but thank you for clarifying that.
