I currently have three different alignments and corridors on one .dwg and its becoming a clustered mess.. Is it possible to turn off these objects or make it so there is "no display" in order to view one object at a time???
Did you create them on separate layers? If so, just Freeze the layers you don't want to see.
I'm now pretty sure thats my problem. When I created the different objects I simply kept using the same default layer thus all of them are on the same layer..... BONER Move! :x
I should be able to go back and move re-organize into different layers right??? :unsure:
