CADDuct Alias Edit
Is there an aliasedit in CADDuct where i can change command values? If not, is there a file within AutoCAD/CADDuct that i can modify to suit my needs?
All help welcomed and appreciated. :)
what do you mean exactly by 'command values'?
cadduct commands can be added to the acad.pgp, but i'm guessing you already know this?
err, for example
SECTIONAL will cut a section when i just want it to be SEC or something. Same for ATTATCHER, I'd like it to be ATT. These can be changed in the acad.pgp file then? :?
Z
yep they can! simples!
just type aliasedit in the command line, and add them in!
use whatever shortcut you want, and use the commands in the list you posted a few weeks back.....
here's what's in my acad.pgp
AT,        *ATTACHER
AO,        *ATTACHOFF
AL,        *ALIAS
F2E,       *FILL2ENDS
FF,        *FLEXFILL
MT,        *MOVETEXT
RN,        *RENUMBER
SI,        *SIZE
RT,        *ROTTEXT
VPO,       *VPORTS
QS,        *QSAVE
P,         *PLANVIEW
3,         *3DINSPECT
RD,        *REDRAW
R,         *ROTATE
S,         *SECTIONAL
AE,        *ALIASEDIT
C,         *COPY
CI,        *CIRCLE
TA,        *TAKEOFF
CH,        *CHECK
D,         *DIST
CL,        *REVCLOUD
DL,        *DIMLINEAR
DA,        *DIMALIGNED
RB,        *REBUILDALL
E,         *ELEVS
DB,        *EDITDBASE
DE,        *DETECT
SA,        *SHOWALL
HT,        *VPTEXTS
HV,        *HIDESELECTEDINVP
SV,        *SHOWALLINVP
AD,        *ADDREPORT
DT,        *removetext
