Guest RODDY1 Posted May 27, 2009 Share Posted May 27, 2009 Hi Everyone Can you please help, I am having problems when i try to activate the Render Enviroment Dialog Box also when i type in _renderenviroment on the command line. It just seems to hang there doing nothing until i press the esc. key I am probably missing something simple. Can anyone help ? Many Thanks Alan Quote Link to comment Share on other sites More sharing options...
ReMark Posted May 27, 2009 Share Posted May 27, 2009 As much as you wouldn't think so it would be helpful to know what version of AutoCAD you're using. Have you installed the service pack for the version of AutoCAD you are using? Have you used this feature in the past without a problem? Quote Link to comment Share on other sites More sharing options...
Guest RODDY1 Posted May 29, 2009 Share Posted May 29, 2009 I am using AutoCad 2010 & 2009. Tried both , still having the same problem . I will try loading any service packs available Many Thanks Quote Link to comment Share on other sites More sharing options...
ReMark Posted May 29, 2009 Share Posted May 29, 2009 Thank you for the update. Please let us know what happens. Quote Link to comment Share on other sites More sharing options...
Cad64 Posted May 29, 2009 Share Posted May 29, 2009 It sounds like the dialog is opening off screen. Did you previously have a dual monitor setup but now only have one? Try this: Hold down Alt and Spacebar then the M key then the Ctrl key and then then use the arrow keys to move the dialog. Quote Link to comment Share on other sites More sharing options...
Guest RODDY1 Posted May 29, 2009 Share Posted May 29, 2009 Hi Cad64 I am working on a dual monitor , but i did try your suggestion. No luck, if i type _renderenvironment on the command line, it waits there . Not allowing me to do anything until i press esc. and then it just goes back to the normal command prompt. Thanks for your help, i will come back to it on Monday Thanks Again Quote Link to comment Share on other sites More sharing options...
