mdbdesign Posted May 28, 2009 Posted May 28, 2009 Just modify layer name and run without any problem. Thank you All office read disclaimer and :lol::lol: Quote
bradb Posted May 28, 2009 Author Posted May 28, 2009 Sorry had to remove lisp I had some errors in the varibles will fix Quote
mdbdesign Posted August 4, 2009 Posted August 4, 2009 Sorry had to remove lisp I had some errors in the varibles will fixBradb, where are you? Quote
bradb Posted August 5, 2009 Author Posted August 5, 2009 Bradb, where are you? Sorry I haven't been online for a while I have the numbers fixed but am still having a problem with the radius on the lap joint flanges. If you draw to 0 rotation its fine but if you draw on 90 180 or 270 the radius draws the wrong direction. Still need to play with it some more but haven't had time. But like I said I have the numbers right I check them 3 times Quote
mdbdesign Posted August 5, 2009 Posted August 5, 2009 Take your time, I am going for beer to kill some time. Let me know when you ready I get you one. Quote
Lectral Posted April 3, 2012 Posted April 3, 2012 Your code sounds like exactly what I'm looking for. Can you please repost it? It doesn't matter to me if it's not 100%. Quote
bradb Posted April 3, 2012 Author Posted April 3, 2012 Your code sounds like exactly what I'm looking for. Can you please repost it? It doesn't matter to me if it's not 100%. I reposted code. The reason some of the larger flanges do not draw properly is because there are no standard size for some features. Ex 2500lb socket welds the bores or stated at time of order and not standard. Quote
Lectral Posted April 14, 2012 Posted April 14, 2012 Wow. There's a lot of data in that file. I'm sure it will come in very handy. Thank you very much. Quote
sayhi_sanjay1 Posted June 12, 2012 Posted June 12, 2012 this is really good its very frindly but all in inch. and we work in both so if u are still working on the same so please think for that also and as in lee mac has prepare more convient way to select in menu bar item andit will be ready. i have checked all in its working good. but i appriceate if u give like. pipe, elbow (90°, 45° & 180°) , tee, reducing tee, reducer (concentric & eccentric), cap, flanges, with selection of double line / single line, 2D / 3D, MM / Inch also. it will help all our members it will help a lot. Quote
