LISP to insert two attributes, pline length, and mtext into block
  • 2 years later...
  • Replies 23
  • Lee Mac
    11
  • chelsea1307
    11
  • doru10
    2
Posted Images
Not too difficult
(defun c:NdUpd  (/ doc spc nd1 nd2 pl mtxt pt ndlst blk turns)
 (vl-load-com)
 (setq doc (vla-get-ActiveDocument (vlax-get-Acad-Object))
       spc (if (zerop (vla-get-activespace doc))
             (if (= (vla-get-mspace doc) :vlax-true)
               (vla-get-modelspace doc)
               (vla-get-paperspace doc))
             (vla-get-modelspace doc)))
 (if (or (tblsearch "BLOCK" "NODE")
         (findfile "NODE.dwg"))
   (if (and (setq nd1 (car (entsel "\nSelect Node 1: ")))
            (eq "INSERT" (cdadr (entget nd1)))
            (eq "PNODE" (strcase (cdr (assoc 2 (entget nd1))))))
     (if (and (setq nd2 (car (entsel "\nSelect Node 2: ")))
              (eq "INSERT" (cdadr (entget nd2)))
              (eq "PNODE" (strcase (cdr (assoc 2 (entget nd2))))))
       (if (and (setq pl (car (entsel "\nSelect Line Object: ")))
                (member (cdadr (entget pl)) '("LWPOLYLINE" "POLYLINE" "LINE")))
           (if (setq pt (getpoint "\nSelect Point for Block: "))
               (and (setq mtxt (car (entsel "\nSelect MTEXT: ")))
                    (wcmatch (cdadr (entget mtxt)) "*TEXT"))
               (setq turns (getint "\nSpecify Number of Turns: "))
               (setq ndlst
                 (mapcar
                   (function
                     (lambda (x)
                       (cdr (assoc 1 (entget (entnext x))))))
                   (list nd1 nd2)))
               (setq blk
                 (vla-insertblock spc
                   (vlax-3D-point (trans pt 1 0)) "NODE.dwg" 1. 1. 1. 0.))
               (foreach att  (vlax-safearray->list
                               (vlax-variant-value
                                 (vla-getAttributes blk)))
                 (cond ((eq "NODE1" (vla-get-TagString att))
                        (vla-put-TextString att (car ndlst)))
                       ((eq "NODE2" (vla-get-TagString att))
                        (vla-put-TextString att (cadr ndlst)))
                       ((eq "LENGTH" (vla-get-TagString att))
                          (rtos
                            (vla-get-Length
                              (vlax-ename->vla-object pl)))))
                       ((eq "TURNS" (vla-get-TagString att))
                        (if turns
                            (rtos turns))))
                       ((eq "COIL" (vla-get-TagString att))
                          (if mtxt
                            (cdr (assoc 1 (entget mtxt))) ""))))))
           (princ "\n<!> No Point Selected <!>"))
         (princ "\n<!> Incorrect LINE Object Selection <!>"))
       (princ "\n<!> Incorrect Selection of NODE 2 <!>"))
     (princ "\n<!> Incorrect Selection of NODE 1 <!>"))
   (princ "\n<!> NODE Block not Found <!>"))
 (princ))
Very interesting LISP Lee-Mac.
It can automatically change node value to the block (after the RE command), when the value PNODE edit and / or length of the polyline?
Sincerely,
Doru
Label and Node.dwg
Sincerely,
Doru
There would probably be a way using Fields to link the values, however this is such old code I would most likely rewrite the whole thing :oops:
Thanks for the reply.
I thought that I add variations and lines as your existing lisp.
I'm beginning to programming and trying to discover and understand as much.
Thank you sincerely.
Doru
