Was just messing around, thought you guys might like this -
Will make any regular polygon on the fly, have a play around with TAB, + and -.
;; Make Polygon by Lee McDonnell (Lee Mac)
;; 29.05.2009
(defun c:mkPly (/ flag doc spc clr pt gr cPt
                 Ang cAng cDis ptLst var)
 (vl-load-com)
 (setq doc (vla-get-ActiveDocument
             (vlax-get-Acad-Object))
       spc (if (zerop
                 (vla-get-activespace doc))
             (if (= (vla-get-mspace doc) :vlax-true) ; Vport
               (vla-get-modelspace doc)
               (vla-get-paperspace doc))
             (vla-get-modelspace doc))
       clr 0)
 (or *mkPly:Side* (setq *mkPly:Side* 4))
 (if (setq pt (getpoint "\nSelect Centre Point: "))
     (while
       (or
         (and
           (setq gr (grread t 7 0)) (eq 5 (car gr)))
         (and
           (eq 2 (car gr))
             (member
               (cadr gr)
                 '(9 43 61 45))))
       (redraw)
       (if
         (and
           (eq 2 (car gr))
           (or
             (eq 43 (cadr gr)) ; +
             (eq 61 (cadr gr)))) ; = (as +)
           (setq *mkPly:Side* (+ *mkPly:Side* (if flag 2 1))
                 clr (1+ clr)))
       (if
         (and
           (eq 2 (car gr))
           (eq 45 (cadr gr))) ; -
           (and (< (if flag 6 3) *mkPly:Side*)
                (setq *mkPly:Side*
                  (- *mkPly:Side* (if flag 2 1))))
           (if (zerop clr)
             (setq clr 5)
             (setq clr (1- clr)))))
       (if
         (and
           (eq 2 (car gr))
           (eq 9 (cadr gr))) ; Tab
           (setq flag (not flag))
           (if flag
             (setq *mkPly:Side* 6))))
       (if (eq 5 (car gr))
           (setq cPt (cadr gr)
                 Ang (/ (* 2. pi) *mkPly:Side*)
                 cAng (angle pt cPt)
                 cDis (distance pt cPt)
                 ptLst (list cPt (polar pt (+ cAng Ang)
                                        (if (and flag (< 5 *mkPly:Side*)
                                                 (zerop (rem *mkPly:Side* 2)))
                                          (/ cDis 3.) cDis))) i 2.)
           (repeat (- *mkPly:Side* 2)
             (setq ptlst
               (append ptlst
                 (list (last ptlst)
                   (polar pt (+ cAng (* i Ang))
                                   (not (zerop (rem i 2))))
                            (/ cDis 3.) cDis)))) i (1+ i)))))
       (grvecs
         (setq ptlst
           (append
             (list (* -1 (1+ (rem clr 6))))
               ptlst (list (last ptlst) cPt)))))
     (if
       (and
         (eq 3 (car gr))
           (listp (cadr gr)))
         (setq ptlst (apply
                       'append
                          (mapcar
                            (function
                              (lambda (x)
                                (list (car x) (cadr x))))
                            (append
                              (unique (cdr ptlst))
                                (list (cadr ptlst))))))
         (setq var
           (vlax-make-variant
             (vlax-safearray-fill
               (vlax-make-safearray
                 vlax-vbdouble
                   (cons 0 (1- (length ptlst))))
               ptlst)))
         (vla-addLightWeightPolyline spc var)))
     (redraw)))
 (princ))
;; CAB
(defun unique (lst / result)
 (reverse
   (while (setq itm (car lst))
     (setq lst (vl-remove itm lst)
           result (cons itm result)))))
Not bad, I like how you can choose size and rotation. But isn't this strikingly similar to the AutoCAD command "Polygon"?
It's definitely neat. Refill I'm surprised you don't like it more with your strange obsession with grread. lol
I do like it. It's hard to fully appreciate Lee's LISPs because most of the time I don't understand them. o.o'
I did notice what could be a bug, however. When on the "star" option, you can tab back to the "polygon" option and keep the same number of sides, but it seems when you're on the "polygon" option and tab into the "star" option, it reverts to a 3-sided star. If you tab back, it goes to a 6-sided polygon. If you subtract a side, it turns into a square.
Still, it's very nice. I like the colours and the use of vectors.
Yup - but maybe quicker :P
Yeah, the star needs an even number of sides (min 6), so I just set it to 6 when you hit tab. But I didn't spend too long writing this, so I guess it could be improved to use the even number below the current number of sides or something similar.
But thanks for the comments guys :D
Lee,
Would you be able to point me in the direction of how you created phantom object?
Much appreciated
Flower
Lee,
Much appreciated
Flower
The GRVECS or GRDRAW functions will draw the "phantom" objects on the screen - a negative colour value for the GRVECS function will indicate a highlighted (dashed) line. :)
Lee
Hi Lee, I don't have a use for it but it is a nice routine!
The thing with teh tab + gives nice stars... getting the christmas feel...
Thanks Marco -
It was just a little bit of fun on the side - just experimenting with GRVECS, GRREAD etc. :)
I'm glad you like it :)
Lee
