nyaromulo Posted May 29, 2009 Posted May 29, 2009 My general lisp stopped working, for example if I type "L" on the command line I should be prompt to draw line" in this case it says "Unknown command "L". Press F1 for help" Same as when I type "C" for a circle and so on. What can I do to bring all these short cut back to work on the command line? I am so used to typing commands...I am dying right now! thank you Quote
Freerefill Posted May 29, 2009 Posted May 29, 2009 If you have a LISP set up to do that, it sounds like you need to re-load it. While you're at it, check to see if it's your startup suite. Though, doing that is not always the best option. Most people prefer to edit their ACAD.pgp file (Tools > Customize > Edit Program Parameters) and create shortcuts there. Quote
Commandobill Posted May 29, 2009 Posted May 29, 2009 Like freerefill said your pgp file should be set up to do this.... heres what mine looks like ; ; ; Program Parameters File For AutoCAD 2008 ; External Command and Command Alias Definitions ; Copyright (C) 1997-2007 by Autodesk, Inc. All Rights Reserved. ; Each time you open a new or existing drawing, AutoCAD searches ; the support path and reads the first acad.pgp file that it finds. ; -- External Commands -- ; While AutoCAD is running, you can invoke other programs or utilities ; such Windows system commands, utilities, and applications. ; You define external commands by specifying a command name to be used ; from the AutoCAD command prompt and an executable command string ; that is passed to the operating system. ; -- Command Aliases -- ; The Command Aliases section of this file provides default settings for ; AutoCAD command shortcuts. Note: It is not recommended that you directly ; modify this section of the PGP file., as any changes you make to this section of the ; file will not migrate successfully if you upgrade your AutoCAD to a ; newer version. Instead, make changes to the new ; User Defined Command Aliases ; section towards the end of this file. ; -- User Defined Command Aliases -- ; You can abbreviate frequently used AutoCAD commands by defining ; aliases for them in the User Defined Command Aliases section of acad.pgp. ; You can create a command alias for any AutoCAD command, ; device driver command, or external command. ; Recommendation: back up this file before editing it. To ensure that ; any changes you make to PGP settings can successfully be migrated ; when you upgrade to the next version of AutoCAD, it is suggested that ; you make any changes to the default settings in the User Defined Command ; Aliases section at the end of this file. ; External command format: ; <Command name>,[<Shell request>],<Bit flag>, [*]<Prompt>, ; The bits of the bit flag have the following meanings: ; Bit 1: if set, don't wait for the application to finish ; Bit 2: if set, run the application minimized ; Bit 4: if set, run the application "hidden" ; Bit 8: if set, put the argument string in quotes ; ; Fill the "bit flag" field with the sum of the desired bits. ; Bits 2 and 4 are mutually exclusive; if both are specified, only ; the 2 bit is used. The most useful values are likely to be 0 ; (start the application and wait for it to finish), 1 (start the ; application and don't wait), 3 (minimize and don't wait), and 5 ; (hide and don't wait). Values of 2 and 4 should normally be avoided, ; as they make AutoCAD unavailable until the application has completed. ; ; Bit 8 allows commands like DEL to work properly with filenames that ; have spaces such as "long filename.dwg". Note that this will interfere ; with passing space delimited lists of file names to these same commands. ; If you prefer multiplefile support to using long file names, turn off ; the "8" bit in those commands. ; Examples of external commands for command windows DEL, DEL, 8,File to delete: , DIR, DIR, 8,File specification: , SH, , 1,*OS Command: , SHELL, , 1,*OS Command: , START, START, 1,*Application to start: , TYPE, TYPE, 8,File to list: , ; Examples of external commands for Windows ; See also the (STARTAPP) AutoLISP function for an alternative method. EXPLORER, START EXPLORER, 1,, NOTEPAD, START NOTEPAD, 1,*File to edit: , PBRUSH, START PBRUSH, 1,, ; Command alias format: ; <Alias>,*<Full command name> ; The following are guidelines for creating new command aliases. ; 1. An alias should reduce a command by at least two characters. ; Commands with a control key equivalent, status bar button, ; or function key do not require a command alias. ; Examples: Control N, O, P, and S for New, Open, Print, Save. ; 2. Try the first character of the command, then try the first two, ; then the first three. ; 3. Once an alias is defined, add suffixes for related aliases: ; Examples: R for Redraw, RA for Redrawall, L for Line, LT for ; Linetype. ; 4. Use a hyphen to differentiate between command line and dialog ; box commands. ; Example: B for Block, -B for -Block. ; ; Exceptions to the rules include AA for Area, T for Mtext, X for Explode. ; -- Sample aliases for AutoCAD commands -- ; These examples include most frequently used commands. NOTE: It is recommended ; that you not make any changes to this section of the PGP file to ensure the ; proper migration of your customizations when you upgrade to the next version of ; AutoCAD. The aliases listed in this section are repeated in the User Custom ; Settings section at the end of this file, which can safely be edited while ; ensuring your changes will successfully migrate. 3A, *3DARRAY 3DMIRROR, *MIRROR3D 3DNavigate,*3DWALK 3DO, *3DORBIT 3DW, *3DWALK 3F, *3DFACE 3M, *3DMOVE 3P, *3DPOLY 3R, *3DROTATE A, *ARC AC, *BACTION ADC, *ADCENTER AECTOACAD, *-ExportToAutoCAD AA, *AREA AL, *ALIGN 3AL, *3DALIGN AP, *APPLOAD AR, *ARRAY -AR, *-ARRAY ATI, *ATTIPEDIT ATT, *ATTDEF -ATT, *-ATTDEF ATE, *ATTEDIT -ATE, *-ATTEDIT ATTE, *-ATTEDIT B, *BLOCK -B, *-BLOCK BC, *BCLOSE BE, *BEDIT BH, *HATCH BO, *BOUNDARY -BO, *-BOUNDARY BR, *BREAK BS, *BSAVE BT, *MAPTRIM BVS, *BVSTATE C, *CIRCLE CAM, *CAMERA CB, *COPYBASE CH, *PROPERTIES -CH, *CHANGE CHA, *CHAMFER CHK, *CHECKSTANDARDS CLI, *COMMANDLINE COL, *COLOR COLOUR, *COLOR CO, *COPY CP, *COPY CT, *CTABLESTYLE CYL, *CYLINDER D, *DIMSTYLE DAL, *DIMALIGNED DAN, *DIMANGULAR DAR, *DIMARC JOG, *DIMJOGGED DBA, *DIMBASELINE DBC, *DBCONNECT DC, *ADCENTER DCE, *DIMCENTER DCENTER, *ADCENTER DCO, *DIMCONTINUE DDA, *DIMDISASSOCIATE DDI, *DIMDIAMETER DED, *DIMEDIT DI, *DIST DIV, *DIVIDE DJL, *DIMJOGLINE DJO, *DIMJOGGED DL, *DATALINK DLI, *DIMLINEAR DLU, *DATALINKUPDATE DO, *DONUT DOR, *DIMORDINATE DOV, *DIMOVERRIDE DR, *DRAWORDER DRA, *DIMRADIUS DRE, *DIMREASSOCIATE DRM, *DRAWINGRECOVERY DS, *DSETTINGS DST, *DIMSTYLE DT, *TEXT DV, *DVIEW DX, *DATAEXTRACTION E, *ERASE ED, *DDEDIT EL, *ELLIPSE ER, *EXTERNALREFERENCES EX, *EXTEND EXIT, *QUIT EXP, *EXPORT EXT, *EXTRUDE F, *FILLET FI, *FILTER FREEPOINT, *POINTLIGHT FSHOT, *FLATSHOT G, *GROUP -G, *-GROUP GD, *GRADIENT GEO, *GEOGRAPHICLOCATION GR, *DDGRIPS H, *HATCH -H, *-HATCH HE, *HATCHEDIT HI, *HIDE I, *INSERT -I, *-INSERT IAD, *IMAGEADJUST IAT, *IMAGEATTACH ICL, *IMAGECLIP IM, *IMAGE -IM, *-IMAGE IMP, *IMPORT IN, *INTERSECT INF, *INTERFERE IO, *INSERTOBJ J, *JOIN L, *LINE LA, *LAYER -LA, *-LAYER LAS, *LAYERSTATE LE, *QLEADER LEN, *LENGTHEN LIS, *LAYISO LI, *LIST LINEWEIGHT, *LWEIGHT LMAN, *LAYERSTATE LO, *-LAYOUT LS, *LIST LT, *LINETYPE -LT, *-LINETYPE LTYPE, *LINETYPE -LTYPE, *-LINETYPE LTS, *LTSCALE LW, *LWEIGHT M, *MOVE MA, *MATCHPROP MAT, *MATERIALS ME, *MEASURE MI, *MIRROR ML, *MLINE MLA, *MLEADERALIGN MLC, *MLEADERCOLLECT MLD, *MLEADER MLE, *MLEADEREDIT MLS, *MLEADERSTYLE MO, *PROPERTIES MS, *MSPACE MSM, *MARKUP MT, *MTEXT MV, *MVIEW NORTH, *GEOGRAPHICLOCATION NORTHDIR, *GEOGRAPHICLOCATION O, *OFFSET OP, *OPTIONS ORBIT, *3DORBIT OS, *OSNAP -OS, *-OSNAP P, *PAN -P, *-PAN PA, *PASTESPEC PARAM, *BPARAMETER PARTIALOPEN, *-PARTIALOPEN PE, *PEDIT PL, *PLINE PO, *POINT POL, *POLYGON PR, *PROPERTIES PRCLOSE, *PROPERTIESCLOSE PROPS, *PROPERTIES PRE, *PREVIEW PRINT, *PLOT PS, *PSPACE PSOLID, *POLYSOLID PTW, *PUBLISHTOWEB PU, *PURGE -PU, *-PURGE PYR, *PYRAMID QC, *QUICKCALC QCUI, *QUICKCUI R, *REDRAW RA, *REDRAWALL RC, *RENDERCROP RE, *REGEN REA, *REGENALL REC, *RECTANG REG, *REGION REN, *RENAME -REN, *-RENAME REV, *REVOLVE RO, *ROTATE RP, *RENDERPRESETS RPR, *RPREF RR, *RENDER RW, *RENDERWIN S, *STRETCH SC, *SCALE SCR, *SCRIPT SE, *DSETTINGS SEC, *SECTION SET, *SETVAR SHA, *SHADEMODE SL, *SLICE SN, *SNAP SO, *SOLID SP, *SPELL SPL, *SPLINE SPLANE, *SECTIONPLANE SPE, *SPLINEDIT SSM, *SHEETSET ST, *STYLE STA, *STANDARDS SU, *SUBTRACT T, *MTEXT -T, *-MTEXT TA, *TABLET TB, *TABLE TC, *TCASE TH, *THICKNESS TI, *TILEMODE TO, *TOOLBAR TOL, *TOLERANCE TOR, *TORIENT TP, *TOOLPALETTES TR, *TRIM TS, *TABLESTYLE UC, *UCSMAN UN, *UNITS -UN, *-UNITS UNI, *UNION V, *VIEW -V, *-VIEW VP, *DDVPOINT -VP, *VPOINT VS, *VSCURRENT VSM, *VISUALSTYLES -VSM, *-VISUALSTYLES W, *WBLOCK -W, *-WBLOCK WE, *WEDGE X, *EXPLODE XA, *XATTACH XB, *XBIND -XB, *-XBIND XC, *XCLIP XL, *XLINE XR, *XREF -XR, *-XREF Z, *ZOOM ; The following are alternative aliases and aliases as supplied ; in AutoCAD Release 13. AV, *DSVIEWER CP, *COPY DIMALI, *DIMALIGNED DIMANG, *DIMANGULAR DIMBASE, *DIMBASELINE DIMCONT, *DIMCONTINUE DIMDIA, *DIMDIAMETER DIMED, *DIMEDIT DIMTED, *DIMTEDIT DIMLIN, *DIMLINEAR DIMORD, *DIMORDINATE DIMRAD, *DIMRADIUS DIMSTY, *DIMSTYLE DIMOVER, *DIMOVERRIDE LEAD, *LEADER TM, *TILEMODE ; Aliases for Hyperlink/URL Release 14 compatibility SAVEURL, *SAVE OPENURL, *OPEN INSERTURL, *INSERT ; Aliases for commands discontinued in AutoCAD 2000: AAD, *DBCONNECT AEX, *DBCONNECT ALI, *DBCONNECT ASQ, *DBCONNECT ARO, *DBCONNECT ASE, *DBCONNECT DDATTDEF, *ATTDEF DDATTEXT, *ATTEXT DDCHPROP, *PROPERTIES DDCOLOR, *COLOR DDLMODES, *LAYER DDLTYPE, *LINETYPE DDMODIFY, *PROPERTIES DDOSNAP, *OSNAP DDUCS, *UCS ; Aliases for commands discontinued in AutoCAD 2004: ACADBLOCKDIALOG, *BLOCK ACADWBLOCKDIALOG, *WBLOCK ADCENTER, *ADCENTER BMAKE, *BLOCK BMOD, *BLOCK BPOLY, *BOUNDARY CONTENT, *ADCENTER DDATTE, *ATTEDIT DDIM, *DIMSTYLE DDINSERT, *INSERT DDPLOTSTAMP, *PLOTSTAMP DDRMODES, *DSETTINGS DDSTYLE, *STYLE DDUCS, *UCSMAN DDUCSP, *UCSMAN DDUNITS, *UNITS DDVIEW, *VIEW DIMHORIZONTAL, *DIMLINEAR DIMROTATED, *DIMLINEAR DIMVERTICAL, *DIMLINEAR DOUGHNUT, *DONUT DTEXT, *TEXT DWFOUT, *PLOT DXFIN, *OPEN DXFOUT, *SAVEAS PAINTER, *MATCHPROP PREFERENCES, *OPTIONS RECTANGLE, *RECTANG SHADE, *SHADEMODE VIEWPORTS, *VPORTS ; Aliases for commands discontinued in AutoCAD 2007: RMAT, *MATERIALS FOG, *RENDERENVIRONMENT FINISH, *MATERIALS SETUV, *MATERIALMAP SHOWMAT, *LIST RFILEOPT, *RENDERPRESETS RENDSCR, *RENDERWIN ; AutoCAD Map Aliases ADELOGIN, *MAPLOGIN MAPADMIN, *MAPTOPOADMIN MAPBROWSELPN, *MAPBROWSELINK MAPDEFINELPN, *MAPDEFINELT MAPQUERY, *MAPTOPOQUERY MAPWSEXECUTEQUERY, *MAPWSQUERYEXECUTE MAPABOUT, *ABOUT MAPEXPORTMAPGUIDE, *MAP2SDF MAPIMPORTMAPGUIDE, *MAPSDFIN ; -- User Defined Command Aliases -- ; Make any changes or additions to the default AutoCAD command aliases in ; this section to ensure successful migration of these settings when you ; upgrade to the next version of AutoCAD. If a command alias appears more ; than once in this file, items in the User Defined Command Alias take ; precedence over duplicates that appear earlier in the file. ; **********----------********** ; No xlate ; DO NOT REMOVE Quote
Freerefill Posted May 29, 2009 Posted May 29, 2009 Fun tip: See the alias for the Shell command? You can open up programs and files with AutoCAD using that and the other external commands, which allows the AutoCAD command prompt to act as a sort of shell for the DOS command prompt. If you're clever enough, you can create a playlist for all your favorite songs or movies, or even websites! Quote
nyaromulo Posted May 29, 2009 Author Posted May 29, 2009 Freerefill & Commandobill, I have acad.pgp file under support file. When I go to (Tools > Customize > Edit Program Parameters), I see the file well, but I do not want to edit it though! I just want to load it to AutoCAD to be able to use, since it can’t get it through support file. What should I do? thank you two Quote
Freerefill Posted May 29, 2009 Posted May 29, 2009 Your acad.pgp file should load every time you start AutoCAD and open a new drawing, and don't worry about editing it, as long as you create what you need exactly as you see all the other shortcuts, you won't ruin anything. If you're still worried, we can help you there as well. If your acad.pgp file doesn't seem to be working, try the REINIT command. I don't know about everyone else, but I rarely use shortcuts or macros. All of my "shortcuts" are in fact mini LISPs, and I load them all on startup. If you're using the same system, you'll have to check to see if your LISP (or LISPs) are still being loaded. Quote
nyaromulo Posted June 1, 2009 Author Posted June 1, 2009 I tried the command "REINIT" but an error come says "Dialogs are not available because DCL files are not loaded" I went through "C" drive and there are so many files with (*.dcl) under support files, which should be available every time I open AutoCAD. Any idea why this occurs? Quote
Lee Mac Posted June 1, 2009 Posted June 1, 2009 May be a silly suggestion, but have you checked what your support path actually is? Someone may have tampered with it inadvertently. Go to Tools > Options > Files > Search Path... (top one) Quote
nyaromulo Posted June 1, 2009 Author Posted June 1, 2009 Oh I am back: I check my support files, all seems to be attached to the right folders/files. I am puzzled! Quote
Freerefill Posted June 2, 2009 Posted June 2, 2009 My two cents... This seems to have gone beyond a LISP not loading properly; it sounds like several things are not being loaded. This could be a problem with AutoCAD itself, and the entire thing may need to be reinstalled. Quote
eldon Posted June 2, 2009 Posted June 2, 2009 Or even try a re-boot. My AutoCAD sometimes does not load properly at a new session, menus and aliases. But in my case, a restart of the computer sorts it (until the next time) Quote
nyaromulo Posted June 9, 2009 Author Posted June 9, 2009 I reinstalled the program, no more errors now, Oh what a thing! thank you Quote
