P_c Posted June 2, 2009 Posted June 2, 2009 Hi, I have a title block set up with attribute text for version, project name, revision comments etc.. When i update the title block i need to realign the text to the position on the new one. I used the attsync command and it worked but the problem is that it swaps the text around. Eg, it replaces the version with revision comments. Is there a way to stop this. Cheers Quote
AQucsaiJr Posted June 2, 2009 Posted June 2, 2009 I use the ATTSYNC command all the time and don't have this problem. Are you changing the TAG's at all? Quote
P_c Posted June 2, 2009 Author Posted June 2, 2009 No, but i just found that there are some tags that have the same name, which i am guessing is why they are swaping. Not fun. Why can't the text just play nice and stay with its original tag. Quote
