Hi,
Arrowhead question...
How can you add an arrowhead to an arc? I'm wanting to put a "ramp up" note on a curved ramp.
Thanks,
Nick
P.S. - Autocad 2008
Use Multileader in the Dimension menu. First click is where you want the test second is wher you want an arrowhead. Then you can edit via properties if the arrow needs to have the size changed.
