Hi,
Like CTRL-TAB cycles through open drawings, is there a way I can cycle through the current drawing's layouts with lisp and tie it into a keyboard shortcut like CTRL-ALT-TAB or something?
I can set up the keyboard shortcut afterwards of course, its just the lips routine for cycling to the next layout i need help with..
I could do this in VBA but wouldn't lisp be slightly quicker and easier to incorporate?
(defun c:slay(/ actDoc)
 (vl-load-com)
 (vlax-for l (vla-get-Layouts
	(setq actDoc(vla-get-ActiveDocument
	  (vlax-get-acad-object))))
   (getint "\nPress Spacebar for next Layout or Esc to Quit... ")
   (vla-put-ActiveLayout actDoc l)
   ); end vlax-for
 ); end of c:slay
Hi ASMI,
That works great, but I have added it to a command and created a keyboard shortcut for it (CTRL+RIGHT) (right arrow key) and everytime it asked me for the input, but i just want it to step to the next layout to the right. I commented out the input line and it just crashed my pc as it was trying to loop through all layouts by the seems of it..
Anyway, sorry if i wasn't clear in my first post. But now i know what i want, I want one command to step to the next layout to the right and one for the going back one, stepping to the left, which i'll tag to a CTRL+LEFT shortcut command..
What about standard CTRL+Page Up and CTRL+Page Down?
Hahahaha, i didn't even know that existed, what a donut, lol
Ok, well i shall use that then, lol. Thanks ASMI
  • 6 years later...
i'm looking for autocad lisp routine for using arrow key to advance layout tabs
thank you
Have a look at my GOTO.lsp wrote it to do just that goto any layout note goto 0 is modelspace. This is not latest version as can use page 99 and it will go to last page will post later.
(defun C:goto ( / lay num)
(setq num (getint "\nEnter tab number"))
(vlax-for lay (vla-get-Layouts (vla-get-activedocument (vlax-get-acad-object)))
(if (= num (vla-get-taborder lay))
 (setvar "ctab" (vla-get-name lay))
) ; if
) ; for
) ; defun
(C:goto)
