Grenco Posted June 2, 2009 Posted June 2, 2009 Good day all, In our company we draw P&ID's with autocad. We use MS Acces (.mdb) files as database for all the components in each drawing so we can make all kinds of itemlists. Most information is in the block its attributes. For now.. Everything is working ok. When we add something to the drawing the following VBA comes in; Private Sub AcadDocument_ObjectAdded(ByVal Object As Object) Dim G_tmp_db, G_name_add, G_blname, G_combbl As String On Error GoTo Err_objera Call G_frmt_chk G_tmp_db = Left(G_dwg_path, (Len(G_dwg_path) - 4)) & "_tmpblk" G_name_add = Mid(TypeName(Object), 2) Set dbblock = opendatabase(G_tmp_db) Set rsblock = dbblock.OpenRecordset("Blocks", dbOpenTable) If (G_name_add = "AcadBlockReference") Then If ((Left(Object.Name, 3) = "G_B") Or (Left(Object.Name, 3) = "G_E") Or _ (Left(Object.Name, 3) = "G_I") Or (Left(Object.Name, 3) = "G_A")) Then rsblock.AddNew rsblock("ObjectID") = Object.ObjectID rsblock("Handle") = Object.Handle rsblock.Update rsblock.Close dbblock.Close Set rsblock = Nothing Set dbblock = Nothing Dim G_dbf_path As String G_dwg_path = thisdrawing.Path & "\" & thisdrawing.Name G_dbf_path = Left(G_dwg_path, (Len(G_dwg_path) - 4)) & "-PID.mdb" 'Verbinding maken met database Set dbInfo = opendatabase(G_dbf_path) Set rsInfo = dbInfo.OpenRecordset("Attributes", dbOpenTable) Set rsData = dbInfo.OpenRecordset("Add_info", dbOpenTable) Set rsPED = dbInfo.OpenRecordset("PED_info", dbOpenTable) Set rsLink = dbInfo.OpenRecordset("Link_info", dbOpenTable) Set rsCdesc = dbInfo.OpenRecordset("Client_desc_info", dbOpenTable) ''For Each elem In ThisDrawing.ModelSpace With Object If ((.HasAttributes) And (Left(elem.Name, 3) = "G_B") Or (Left(elem.Name, 3) = "G_E") Or (Left(elem.Name, 3) = "G_I")) Then 'Gea_ordernummer = thisdrawing.GetVariable("PROJECTNAME") Call GEA_code_start.G_update_db(Object, Gea_ordernummer) 'MsgBox "Instructie" & thisdrawing.GetVariable("CMDNAMES") Else End If End With rsData.Close rsPED.Close rsLink.Close rsCdesc.Close rsInfo.Close dbInfo.Close Set rsData = Nothing Set rsPED = Nothing Set rsLink = Nothing Set rsCdesc = Nothing Set rsInfo = Nothing Set dbInfo = Nothing End If End If thisdrawing.EndUndoMark Exit Sub Err_objera: If Err.Number = 3024 Then Exit Sub Else Resume Next End Sub Public Sub G_frmt_chk() Dim l As Integer G_name_chk = False G_dwg_path = thisdrawing.Path & "\" & thisdrawing.Name G_dwg_name = UCase(thisdrawing.Name) l = Len(G_dwg_name) G_dwg_name = Left(G_dwg_name, l - 4) G_name_chk = (Left(G_dwg_name, 1) Like "~") writelock = thisdrawing.GetVariable("WRITESTAT") If writelock = 0 Then G_name_chk = False End If End Sub But we want to make our symbols (blocks with attributes) dynamic (visability states). When we add a dynamic block, the insertion time gets too long! Every element in the dynamic block is an "object added" so every element has to go through VBA above. When the dynamic blocks' visability state is changed. It also runs through the VBA. This makes you wait for approx 15 to 45 seconds. Does anyone now how to get it faster? Maybe can I filter dynamic blocks and other elements so only the attributes get through? Any other ideas? Thanks a lot for any tips! Quote
hugha Posted June 2, 2009 Posted June 2, 2009 You could cut down database opening overhead by rearranging so dbblock and rsblock are created just before (and only if) they are required: ... If (G_name_add = "AcadBlockReference") Then If ((Left(Object.Name, 3) = "G_B") Or (Left(Object.Name, 3) = "G_E") Or _ (Left(Object.Name, 3) = "G_I") Or (Left(Object.Name, 3) = "G_A")) Then Set dbblock = opendatabase(G_tmp_db) Set rsblock = dbblock.OpenRecordset("Blocks", dbOpenTable) rsblock.AddNew rsblock("ObjectID") = Object.ObjectID rsblock("Handle") = Object.Handle rsblock.Update rsblock.Close dbblock.Close Set rsblock = Nothing Set dbblock = Nothing ... Hope this helps, Hugh Adasmon Cadro Pty Ltd www.hatchkit.com.au Quote
Grenco Posted June 23, 2009 Author Posted June 23, 2009 Sorry for the late response... Thanks for your reply. I still havent tested it but it looks more logical. Quote
