Commandobill Posted June 7, 2009 Share Posted June 7, 2009 Wow, i really need to learn to look over my code before posting. Why do you need to add one to the row count, and take one from the column count? (is it just that the program returns one more column than needed and the number last row used? - if that makes sense...) In this instance the column was going to return as an even number because we were adding one thing to two columns. I wanted it to go back one column before writing. Then i needed to add one to the row so that it didnt write over my last row. Understand? As far as using file with vla-add. That was just a "rush" error. I was trying to get it out and didnt look. Same with getting the "usedrange" with the new file. I decided to add the option in last minute so i just copied the code above it and forgot to remove a few things. Quote Link to comment Share on other sites More sharing options...
Commandobill Posted June 7, 2009 Share Posted June 7, 2009 And i dont mind you ripping apart my code. Hopefully ill learn something from it too. Lisp is my first programming language so my methods are still new. Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted June 7, 2009 Share Posted June 7, 2009 In this instance the column was going to return as an even number because we were adding one thing to two columns. I wanted it to go back one column before writing. Then i needed to add one to the row so that it didnt write over my last row. Understand? So you are assuming that the existing file has data that spans two columns here :wink: As far as using file with vla-add. That was just a "rush" error. I was trying to get it out and didnt look. Same with getting the "usedrange" with the new file. I decided to add the option in last minute so i just copied the code above it and forgot to remove a few things. So what should it be instead of file? Quote Link to comment Share on other sites More sharing options...
Commandobill Posted June 8, 2009 Share Posted June 8, 2009 So you are assuming that the existing file has data that spans two columns here :wink: So what should it be instead of file? Yes i am assuming that. (vla-add obj) is the same as (vlax-invoke-method obj "Add") no further description is necessary to make it run. Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted June 8, 2009 Share Posted June 8, 2009 Yes i am assuming that. (vla-add obj) is the same as (vlax-invoke-method obj "Add") no further description is necessary to make it run. Ahh OK, I see - thanks mate Quote Link to comment Share on other sites More sharing options...
SydneyCB Posted June 10, 2009 Share Posted June 10, 2009 I read in a early post that you can make it export text only from a certain layer or layers, could you to modify it so it does that, I'm not familiar with writing lisps but i'm trying to figure it out. Quote Link to comment Share on other sites More sharing options...
Commandobill Posted June 10, 2009 Share Posted June 10, 2009 the selection set in the beginning tells it what to export so... (setq ss (ssget "_X" (list (cons 0 "*TEXT, INSERT") (cons 8 "LAYERNAME")))) if you change the layername in there you could then add a comma for extra layers.... Quote Link to comment Share on other sites More sharing options...
SydneyCB Posted June 10, 2009 Share Posted June 10, 2009 the selection set in the beginning tells it what to export so... (setq ss (ssget "_X" (list (cons 0 "*TEXT, INSERT") (cons 8 "LAYERNAME")))) if you change the layername in there you could then add a comma for extra layers.... k thanks, i'll try playing with it, the codes still all look greek to me but are startng to make sense Quote Link to comment Share on other sites More sharing options...
SteveK Posted July 28, 2009 Share Posted July 28, 2009 If anyone's interested I have been modifying the code posted previously by CommandoBill and Lee Mac to take text that is in a table format in autocad (not an actual autocad table) with 4 columns and place it in roughly the same table format in excel. EDIT: I had a minor problem with which row to start on but that is fixed up now thanks for Lee. Here's the code: ; Select TEXT and program will output Text into one of five columns in Excel ; Works reasonably ok however if there are meant to be cell gaps it will not pick them up. (defun c:t2xl (/ ss xlApp xlCells row col Txt_Str x_coord ens_unsorted ens_y_sorted Col1_x Col2_x Col3_x Col4_x col_prev) (vl-load-com) (if (setq ss (ssget '((0 . "*TEXT")))) (progn (setq xlApp (vlax-get-or-create-object "Excel.Application") xlCells (vlax-get-property (vlax-get-property (vlax-get-property (vlax-invoke-method (vlax-get-property xlApp "Workbooks") "Add") "Sheets") "Item" 1) "Cells") row 1 col 1) (vla-put-visible xlApp :vlax-true) (setq list1 (list) list2 (list) list3 (list) list4 (list) list5 (list)) ; Sort selection set by y co-ord: The problem is if the y co-ord is the same it will delete the entity. (setq ens_unsorted (mapcar 'vlax-ename->vla-object (vl-remove-if 'listp (mapcar 'cadr (ssnamex ss))))) (setq ens_y_sorted (vl-sort ens_unsorted '(lambda (e1 e2) (> (cadr (vlax-get e1 'InsertionPoint)) (cadr (vlax-get e2 'InsertionPoint)))))) ;(princ ens_y_sorted) (foreach y ens_y_sorted (setq Txt_Str (vlax-get y 'TextString) x_coord (car (vlax-get y 'InsertionPoint))) ;y_coord (cadr (vlax-get y 'InsertionPoint))) (Cond ((Not Col1_x) (setq Col1_x x_coord list1 (append list1 (List Txt_Str)))) ((EQUAL x_coord Col1_x 5.) ; Fuzz factors is 5 (setq list1 (append list1 (List Txt_Str)))) ((OR (Not Col2_x) (= Col1_x Col2_x)) (setq Col2_x x_coord list2 (append list2 (List Txt_Str)))) ((EQUAL x_coord Col2_x 5.) (setq list2 (append list2 (List Txt_Str)))) ((OR (Not Col3_x) (= Col2_x Col3_x)) (setq Col3_x x_coord list3 (append list3 (List Txt_Str)))) ((EQUAL x_coord Col3_x 5.) (setq list3 (append list3 (List Txt_Str)))) ((OR (Not Col4_x) (= Col3_x Col4_x)) (setq Col4_x x_coord list4 (append list4 (List Txt_Str)))) ((EQUAL x_coord Col4_x 5.) (setq list4 (append list4 (List Txt_Str)))) (T ; Else put it in col 5 (setq list5 (append list5 (List Txt_Str))) )) ) ; End For ;;; (princ "\n1\n") ;;; (princ list1) ;;; (princ "\n2\n") ;;; (princ list2) ;;; (princ "\n3\n") ;;; (princ list3) ;;; (princ "\n4\n") ;;; (princ list4) ;;; (princ "\n5\n") ;;; (princ list5) (foreach item list1 (vlax-put-property xlCells "Item" row col item) (setq col 1 row (1+ row)) ) (setq row 1) (foreach item list2 (vlax-put-property xlCells "Item" row col item) (setq col 2 row (1+ row)) ) (setq row 1) (foreach item list3 (vlax-put-property xlCells "Item" row col item) (setq col 3 row (1+ row)) ) (setq row 1) (foreach item list4 (vlax-put-property xlCells "Item" row col item) (setq col 4 row (1+ row)) ) (setq row 1) (foreach item list5 (vlax-put-property xlCells "Item" row col item) (setq col 5 row (1+ row)) ) (mapcar 'vlax-release-object (list xlApp xlCells)) )(Princ "Nothing Selected")) (princ)) Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted July 29, 2009 Share Posted July 29, 2009 I believe it starts from row 1 Quote Link to comment Share on other sites More sharing options...
SteveK Posted July 29, 2009 Share Posted July 29, 2009 Ofcourse! Sorry and thanks. I'll re-update my post. Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted July 29, 2009 Share Posted July 29, 2009 Glad I could help Quote Link to comment Share on other sites More sharing options...
PRABHAKARAN Posted May 25, 2013 Share Posted May 25, 2013 Hi, this is prabha. One help, i want to export autocad text to excel in the same column and row without image..... I need the lisp for that option. Can you please help for that? Thanks, prabha... Quote Link to comment Share on other sites More sharing options...
fixo Posted May 25, 2013 Share Posted May 25, 2013 Try this code to solve your issue, I can be more help ;;---------------------------- code start -------------------------------;; (defun C:CTXL(/ *error* colnum en i ncol nrow path sheetname ss txt x xcells xlapp xlbook xlbooks xlcells xlcolrange xldata xllastcell xlsheet xlsheets) (vl-load-com) (defun *error* (msg) (if (vl-position msg '("console break" "Function cancelled" "quit / exit abort" ) ) (princ "Error!") (princ msg) ) (and xlapp (vl-catch-all-apply 'vlax-release-object (list xlapp))) (princ) ) ;; helpers: (defun lastcell_in_column(excelapp colrange / colcells colnum lastcell rowcount) ;;; author: fixo () 2011 * all rights released (vl-catch-all-apply 'vlax-invoke-method (list excelapp 'volatile)) (setq rowcount (vl-catch-all-apply 'vlax-get-property (list (vlax-get-property colrange 'rows) 'count))) (setq colcells (vl-catch-all-apply 'vlax-get-property (list (vlax-get-property colrange 'parent) 'cells))) (setq colnum (vl-catch-all-apply 'vlax-get-property (list colrange 'column))) ;;return: (setq lastcell (vlax-get-property (vlax-variant-value (vlax-get-property colcells 'item (vlax-make-variant rowcount 3) (vlax-make-variant colnum 3))) 'end (vlax-make-variant -4162 3));<-- (-4162) xlUp ) ) (defun setcelltext(cells row column value) (vl-catch-all-apply 'vlax-put-property (list cells 'Item row column (vlax-make-variant (vl-princ-to-string value) )) ) ;; main part ;; (if (setq ss (ssget '((0 . "TEXT")))) (progn (repeat (setq i (sslength ss)) (setq en (ssname ss (setq i (1- i))) txt (cdr (assoc 1 (entget en))) xldata (cons txt xldata))) (setq xldata (reverse xldata)) (setq path (getfiled "Select Excel file to write :" (getvar "dwgprefix") "xls;xlsx" 16 ) ) (initget 7) (setq sheetname (getint "\nSpecify sheet name : ")) (setq colnum (getstring "\nColumn letter: ")) (alert "Confirm \"Save\" Excel File on Request") (setq xlapp (vlax-get-or-create-object "Excel.Application") xlbooks (vlax-get-property xlapp 'Workbooks) xlbook (vl-catch-all-apply 'vla-open (list xlbooks path)) xlsheets (vlax-get-property xlbook 'Sheets) xlsheet (vlax-get-property xlsheets 'Item sheetname) xcells (vlax-get-property xlsheet 'Cells) ) (vla-put-visible xlapp :vlax-true) (vlax-invoke-method xlsheet 'Activate) (setq xlcolrange (vlax-get-property xcells 'range (strcat colnum ":" colnum))) (setq xllastcell (lastcell_in_column xlapp xlcolrange)) (setq nrow (vlax-get-property xllastcell 'row) ncol (vlax-get-property xllastcell 'column)) (foreach txt xldata (setcelltext xlcolrange nrow ncol txt) (setq nrow (1+ nrow))) (vl-catch-all-apply 'vlax-invoke-method (list (vlax-get-property xlsheet 'Columns)'AutoFit) ) (vlax-invoke-method xlbook 'SaveAs path nil nil nil :vlax-false :vlax-false 1 2 ) (vlax-invoke-method xlbook 'Close :vlax-true) (gc) (vlax-invoke-method xlapp 'Quit) (mapcar '(lambda (x) (vl-catch-all-apply 'vlax-release-object (list x)) ) (list xlcells xlsheet xlsheets xlbook xlbooks xlapp) ) (setq xlapp nil) (gc) (alert (strcat "File saved as:\n" path)) ) ) (*error* nil) (princ) ) (prompt "\n\t\t---\tStart command with CTXL\t---\n") (princ) (or (vl-load-com)(princ)) ;;---------------------------- code end -------------------------------;; Quote Link to comment Share on other sites More sharing options...
pegasus Posted February 2, 2023 Share Posted February 2, 2023 CAN WE ADD LIMITATIONS TO TEXT AND MTEXT IN SPECIAL LAYER HERE? On 6/3/2009 at 5:05 PM, Commandobill said: Well if all of the text objects were on model space and you wanted to use Lee's trick of getting all the objects from all open dwgs you could go with this (defun c:txt2csv (/ fPath fName ofile docs mdlspc drac mdl) (vl-load-com) (setq fPath "C:\\") (setq fName "test.csv") (if (vl-file-directory-p fPath) (progn (setq ofile (open (strcat fPath fName) "a")) (vlax-for docs (vla-get-documents (vlax-get-acad-object)) (setq mdlspc (vla-get-modelspace docs)) (setq drac 0) (vlax-for mdl mdlspc (if (or (= (vla-get-objectname mdl) "AcDbMText") (= (vla-get-objectname mdl) "AcDbText")) (write-line (vla-get-textstring mdl) ofile) ) (setq drac (1+ drac)) ) ) ) ) (close ofile) (princ)) edit: 100th post.... sweet... Quote Link to comment Share on other sites More sharing options...
ronjonp Posted February 2, 2023 Share Posted February 2, 2023 @pegasus Sure (setq fpath "C:\\") (setq fname "test.csv") (if (vl-file-directory-p fpath) (progn (setq ofile (open (strcat fpath fname) "a")) (vlax-for docs (vla-get-documents (vlax-get-acad-object)) (setq mdlspc (vla-get-modelspace docs)) (setq drac 0) (vlax-for mdl mdlspc (if (and (wcmatch (vla-get-objectname mdl) "AcDbMText,AcDbText") (wcmatch (strcase (vla-get-layer mdl)) "LAYER1,LAYER2,LAYER3") ) (write-line (vla-get-textstring mdl) ofile) ) (setq drac (1+ drac)) ) ) ) ) (close ofile) (princ) Quote Link to comment Share on other sites More sharing options...
Steven P Posted February 2, 2023 Share Posted February 2, 2023 58 minutes ago, ronjonp said: @pegasus (if (and (wcmatch (vla-get-objectname mdl) "AcDbMText,AcDbText") (wcmatch (strcase (vla-get-layer mdl)) "LAYER1,LAYER2,LAYER3") ) Will that work with a wildcard too? For example: (wcmatch (vla-get-objectname mdl) "*Text") (though this will also pick up rtext? - Yet to see that in a drawing though) Should also work with a wildcard in the layer name? Quote Link to comment Share on other sites More sharing options...
ronjonp Posted February 2, 2023 Share Posted February 2, 2023 5 minutes ago, Steven P said: Will that work with a wildcard too? For example: (wcmatch (vla-get-objectname mdl) "*Text") (though this will also pick up rtext? - Yet to see that in a drawing though) Should also work with a wildcard in the layer name? Wildcards will definitely work ... look at the reference HERE. 1 Quote Link to comment Share on other sites More sharing options...
