HOW DO I DELETE THIS FROM DATA BASE ,AND WHAT IS IT ? Handle = 19dbd
Where did you get that at? The handle is a unique (per drawing) ID tag for an entity.
You could use this bit of lisp code to select the object.
[color=blue][font="Courier New"]
(command "._select" (handent "19dbd"))
[/font][/color]
If you were bringing in attributes, Handle information would also come along. In order for you to bring you information from the data base back to the drawing would require handle information to be there to get back to the proper block or entity.
Every Entity in a drawing has a handle. It remains unchanged throughout the drawing un like the entity name. Best way to store info from one session to another about a specific entity. Thought the handle doesn't change between session a specific entity doesn't have a specific handle.
