I have some .dwg files that I need to convert to GML. I've seen a lot online and on these forums about converting GML to .dwg, and was curious if anyone knew anything about converting these files back to GML.
Thank you in advance for any help you can provide.
i cant answer ur question but to make it easier for someone who can, u should fill out the important bits in ur profile like wat version of autocad ur using.
just click on User CP in the top left of this page, then Edit Profile n fill in the blanks.
AutoDesk Map3D can export DWG files to GML format. It cannot be done with plain AutoCAD if that is what you have.
We aren't currently using autocad, which is why I haven't specified a version. My workplace likes to work with files in GML, but an external data source that we need to work with provided us with several .dwg autocad files. We need to convert them into GML so we can work with them.
