nyaromulo Posted June 3, 2009 Posted June 3, 2009 I opening a drawing using AutoCAD 2009 and a dialog box appears that says "Semantic errors(s) in DCL file ade.dcl. See file acad.dce for details" I looked into the "acad.dce" file and I see so much, I do not know what to fix and what not. Any help? thanks Quote
ReMark Posted June 3, 2009 Posted June 3, 2009 From the CadGuruCool's Tip and Tricks website: When an error occurs in a DCL file, unlike AutoLISP, it is not displayed at the command: prompt in AutoCAD. Instead all the errors are written in a seperate file called ACAD.DCE You can find it in the current directory. But the ACAD.DCE file does not contain all the details by defalut. The Tip is : Include the following statement at the beginning of your DCL file: dcl_settings : defalut_dcl_settings {audit_level=3;} A value of 3 for the audit_level attribute ensures that the error is pinpointed with the line number, along with the nature of error and a few suggestions to rectify the mistake. Quote
Lee Mac Posted June 3, 2009 Posted June 3, 2009 If you could post ade.dcl, I'd be happy to look at it and see if I can find your error for you Quote
