De_Amaral Posted June 4, 2009 Posted June 4, 2009 I'm trying to make a dwg file to insert as block in other drawings. In this file I have 2 attributes that will be changed by the user and another one with a formula field to subtract the values of the first 2 att., but when a insert this block to another drawing, the object id, wich is the reference of the formula, changes, so it doesn't works. How can I fix it? Is that a way to set a permanent id to an object? Quote
