I having a problem opening drawings. Usually when you go to the file drop down and select open a box comes up and you can navigate to the drawing you want to open. Instead of letting me navigate to the drawing I want its asking me to enter the file name on the command line. Its doing the same thing when I want to save the drawing. Instead of letting me navigate to where I want to save my drawing its asking me to enter in the name and location on the command line.
It wasn't doing this before and I don't know what I changed. How do I change it back and what could possibly be wrong with the settings?I'm using AutoCAD Map 2009
set FILEDIA to 1 (at least for autocad not sure for Map)
Try setting FILEDIA to the value 1. Does that fix it?
Dang. Beat out by the young lass.
That was an easy fix, Thanks guys. What is FILEDIA?
I think it stands for file dialog.
check what it says when you F1 it
It controls the display of file navigation dialog boxes. The setting "0" will suppress dialog boxes. Thus our advice to reset the system variable to 1.
checking F1 was for the op, more people should learn how to use it!
I couldn't agree with you more. I think most new users either don't know Help is available or they do not know how to use it.
or they think it is like some programs help and absolutely useless
