Electroman7979 Posted June 4, 2009 Posted June 4, 2009 Can anyone tell me if its possible in ACE 2009 to generate a cable conductor report showing the cable markers used in each cable. I can bring up a list inside the "Insert/Edit Cable Marker" dialog, but I can't save it or export or put on drawings. All I have found in the report gernerator is a list of all the parent cable markers, not each conducter used in each cable. Thanks in advance for the help! -James Quote
Olhado_ Posted July 4, 2009 Posted July 4, 2009 There is a cable to/from list, which I believe shows the path of every conductor in the cable. Quote
