I made a tool for my company in 3D. Now i want to take its print in different views in 2d mode.
But i am unable to set their hidden line.
how to show it..
Pls help me.
punching tool.dwg
how to show it..
Pls help me.
punching tool.dwg
Im not sure if 2006 has the flatshot command.
No need to double post. Thank you.
I didn't quite understand your exact request. Do you want to hidden lines like this? -David
Yes David Bethel thats it...i realy want it...
how did you do it...pls send me the way ....
humair
I use DXB plotting for this type of work.
  • Configure a DXB plotter - See attached
  • Setup the view you want
  • Plot 2 files with different names, 1 with hidden lines ON , 1 with hidden lines OFF
  • Make a new layer
  • Set LTYPE to HIDDEN
  • I set CECOLOR to 8
  • DXBIN the plot file with hidden lines OFF
  • Set LTYPE to CONTINUOUS or BYLAYER
  • I set CECOLOR to 4
  • DXBIN the plot file with hidden line ON
  • I set CECOLOR back to BYLAYER
Hope this helps. -David
No. its difficult to do it... for me...
but sir, i request you to do it withing modeling area. not in plot area.
i did not find my answer yet................
any one help me...
how to show it..
Pls help me.
Checkout OBSCUREDLTYPE and OBSCUREDCOLOR.
