Hello, i'm verry noob with lisp and i have a simple question.
i know its easy to call a lisp function inside acad when they include something like defun:
but how do i call a function when the structure is like this
Option Explicit
Public Sub Main()
code here code here code here
End Sub
Calling functions is pretty much the same no matter what, the only difference I've really come across is whether it's a command or a function. The only difference is whether or not it's preceeded by a c:, like so:
; Command
(defun c:dothis()
 (princ "hello world")
; Function
(defun dothisalso()
 (princ "What's up?")
I hope that answers your question, if not, I could try again ^^'
Im not sure how do i call this code inside autoCAD ... do i need to add a function inside the code?
Option Explicit
Public Sub Main()
   Dim objBlock As AcadBlockReference
   Dim objEnt As AcadEntity
   Dim colHyps As AcadHyperlinks
   Dim fso As FileSystemObject
   Set fso = New FileSystemObject
   For Each objEnt In ThisDrawing.ModelSpace
       If TypeOf objEnt Is AcadBlockReference Then
           Set objBlock = objEnt
           Set colHyps = objBlock.Hyperlinks
           On Error Resume Next ' In case we encounter any blocks that DON'T have hyperlinks
           fso.CopyFile colHyps.Item(0).URL, "E:\Temp\"  ' replace E:\Temp\ with your project directory
       End If
   Next objEnt
   Set fso = Nothing
End Sub
; Command
(defun c:dothis()
; Function
(defun dothisalso()
what he appears to be asking is how to call a vba routine inside cad. and im quite new to vba and the only way i personally know how to run those is through 'vbaide' or 'vbarun'
Not working i tried
(defun c:dothis()
Option Explicit
Public Sub Main()
       End If
   Next objEnt
   Set fso = Nothing
End Sub
and
(defun c:dothis()
       End If
   Next objEnt
   Set fso = Nothing
End Sub
any other idea?
You are mixing up LISP with VBA - two very different things :geek:
how do i call this function...
this is only what i want to know
PLEASE
you should have that file saved as a .dvb so you can make a lisp that looks like this
[color=Black][color=#383838](defun c:LoadMacro ()
(setvar "filedia" 0);//To avoid the VBALOAD dialog box display
(command "_VBALOAD" "c:\\temp\\macro.dvb");<--- change to your vba file
(setvar "filedia" 1);//Reset filedia to 1
(command "_-VBARUN" "macro1");//- To avoid the VBARUN dialog box display
)[/color][/color]
reference : http://usa.autodesk.com/adsk/servlet/ps/item?siteID=123112&id=2888989&linkID=9240617
