ksperopoulos Posted December 5, 2012 Author Posted December 5, 2012 Lee Mac, I made a couple changes to focus on a few layers and raise them to a set elevation instead of being prompted. While it seems to work, do you see anything that I should change to make it work 100% of the time? (defun c:zMov (/ ss z) (vl-load-com) (if (and (setq ss (ssget "_x" '((8 . "M-*-DIMS,M-*-ELEV,M-*-SIZE,M-*-TEXT,P-*-DIMS,P-*-ELEV,P-*-SIZE,P-*-TEXT")))) ) (progn (setq Obj (mapcar 'vlax-ename->vla-object (vl-remove-if 'listp (mapcar 'cadr (ssnamex ss))))) (foreach x Obj (foreach i '(1e99 -1e99) (vla-move x (vlax-3D-point '(0 0 0)) (vlax-3D-point (list 0 0 i))))) (mapcar (function (lambda (x) (vla-move x (vlax-3D-point '(0 0 0)) (vlax-3D-point (list 0 0 600))))) Obj)) (princ "\n<< Incorrect Selection >>")) (princ)) Quote
Lee Mac Posted December 5, 2012 Posted December 5, 2012 Wow - that is some old code! Although probably not as quick, it may be clearer and more intuitive to use: (defun c:zmov ( / s ) (if (setq s (ssget "_X" '((8 . "[PM]-*-*") (8 . "*DIMS,*ELEV,*SIZE,*TEXT")))) (command "_.move" s "" "_non" '(0.0 0.0 0.0) "_non" '(0.0 0.0 1e99) "_.move" s "" "_non" '(0.0 0.0 0.0) "_non" '(0.0 0.0 -1e99) "_.move" s "" "_non" '(0.0 0.0 0.0) "_non" '(0.0 0.0 600.0) ) (princ "\nNo objects found.") ) (princ) ) Quote
ksperopoulos Posted December 5, 2012 Author Posted December 5, 2012 Thanks. Your "new code" is a lot easier on the eyes for a guy STILL learning this stuff! Quote
David Bethel Posted December 5, 2012 Posted December 5, 2012 Wow - that is some old code! (defun c:zmov ( / s ) (if (setq s (ssget "_X" '((8 . "[PM]-*-*") (8 . "*DIMS,*ELEV,*SIZE,*TEXT")))) (command Lee, I don't thing that I've ever seen an ( ssget ) call using group 8 twice.. I don't quite understand the logic. -David Quote
Lee Mac Posted December 5, 2012 Posted December 5, 2012 I don't thing that I've ever seen an ( ssget ) call using group 8 twice.. I don't quite understand the logic. -David Since the ssget filter list has an implied AND logic for all entries in the list, my filter is the equivalent of: (and (wcmatch <layer name> "[PM]-*-*") (wcmatch <layer name> "*DIMS,*ELEV,*SIZE,*TEXT") ) Or, alternatively: (wcmatch <layer name> "[PM]-*-*DIMS,[PM]-*-*ELEV,[PM]-*-*SIZE,[PM]-*-*TEXT") But that's too much typing I'm happy to explain further if the above is unclear. Quote
