Matching bottom of pipe with top of another
I need the bottom of my pipe run to match with the top of another. What I do is to first set the vertical justification of my pipe to 'Bottom' and then use the Match command followed by Elevation. Only problem is that the bottom of my pipe is matched to the center of the second one instead of the top, creating a collision. Any way I can make that work?
