I have this code to MATCH the text of Mtext, Text, Attributes ect..
(defun c:tw  (/ cEnt mEnt)
 (if (and (setq cEnt (car (nentsel "\nSelect Source Text: ")))
          (member (cdr (assoc 0 (entget cEnt)))
                  '("TEXT" "MTEXT" "ATTRIB")))
     (redraw cEnt 3)
     (while (and (setq mEnt (car (nentsel "\nSelect Destination Text: ")))
                 (member (cdr (assoc 0 (entget mEnt)))
       (entmod (subst (assoc 1 (entget cEnt))
                      (assoc 1 (entget mEnt))
                      (entget mEnt))))
     (redraw cEnt 4))
   (princ "\n<!> Incorrect Selection <!>"))
 (princ))
(defun c:mt2  (/ cEnt mEnt sLst)
     (redraw cEnt 3)
     (if (setq ss (ssget "_X" '((-4 . "<NOT") (0 . "TEXT,MTEXT,INSERT") (-4 . "NOT>"))))
       (mapcar '(lambda (x) (redraw x 2)) (setq sLst (mapcar 'cadr (ssnamex ss)))))
                      (entget mEnt)))))
 (command "_regenall")
 (princ))
(defun c:mt3  (/ cEnt ss)
 (vl-load-com)
     (redraw cEnt 3)
     (if (setq ss (ssget '((0 . "TEXT,MTEXT"))))
       (foreach x  (vl-remove-if 'listp
                        (assoc 1 (entget x))
                        (entget x))))))
 (princ))
Can i modify this and how to match a text switch with would reverse 'Text A' & 'Text B'?
Z
  • Replies 23
  • Lee Mac
    9
  • Zorg
    5
  • wizman
    4
  • alanjt
    4
thanks wizman, works great :D
you're welcome zorg, i find that handy also,our thanks goes to the author.
Do you not find that its missing a sub-function, namely: spextm or is it just me?
Surely this is better:
[Works with Attributes also]
[i][color=#990099];; Switch Text Values  by Lee McDonnell[/color][/i]
[i][color=#990099];; 08.06.2009[/color][/i]
[b][color=RED]([/color][/b][b][color=BLUE]defun[/color][/b] c:stv [b][color=RED]([/color][/b][b][color=BLUE]/[/color][/b] ent1 ent2 ObjLst[b][color=RED])[/color][/b]
 [b][color=RED]([/color][/b][b][color=BLUE]vl-load-com[/color][/b][b][color=RED])[/color][/b]
 [b][color=RED]([/color][/b][b][color=BLUE]while[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]not[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]and[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] ent1 [b][color=RED]([/color][/b][b][color=BLUE]car[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]nentsel[/color][/b] [b][color=#ff00ff]"\nSelect 1st Text or Attribute: "[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
                  [b][color=RED]([/color][/b][b][color=BLUE]member[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]cdr[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]assoc[/color][/b] [b][color=#009900]0[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]entget[/color][/b] ent1[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=DARKRED]'[/color][/b][b][color=RED]([/color][/b][b][color=#ff00ff]"MTEXT"[/color][/b] [b][color=#ff00ff]"TEXT"[/color][/b] [b][color=#ff00ff]"ATTRIB"[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
   [b][color=RED]([/color][/b][b][color=BLUE]princ[/color][/b] [b][color=#ff00ff]"\nMissed, Try Again."[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
 [b][color=RED]([/color][/b][b][color=BLUE]while[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]not[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]and[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] ent2 [b][color=RED]([/color][/b][b][color=BLUE]car[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]nentsel[/color][/b] [b][color=#ff00ff]"\nSelect 2nd Text or Attribute: "[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
                  [b][color=RED]([/color][/b][b][color=BLUE]member[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]cdr[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]assoc[/color][/b] [b][color=#009900]0[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]entget[/color][/b] ent2[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=DARKRED]'[/color][/b][b][color=RED]([/color][/b][b][color=#ff00ff]"MTEXT"[/color][/b] [b][color=#ff00ff]"TEXT"[/color][/b] [b][color=#ff00ff]"ATTRIB"[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
 [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] ObjLst [b][color=RED]([/color][/b][b][color=BLUE]mapcar[/color][/b] [b][color=DARKRED]'[/color][/b][b][color=BLUE]vlax-ename->vla-object[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]list[/color][/b] ent1 ent2[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
   [b][color=RED]([/color][/b][b][color=BLUE]function[/color][/b]
     [b][color=RED]([/color][/b][b][color=BLUE]lambda[/color][/b] [b][color=RED]([/color][/b]Obj1 Str[b][color=RED])[/color][/b]
       [b][color=RED]([/color][/b][b][color=BLUE]vla-put-TextString[/color][/b] Obj1 Str[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] ObjLst
   [b][color=RED]([/color][/b][b][color=BLUE]mapcar[/color][/b] [b][color=DARKRED]'[/color][/b][b][color=BLUE]vla-get-TextString[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]reverse[/color][/b] ObjLst[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
 [b][color=RED]([/color][/b][b][color=BLUE]princ[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
Thanks for pointing lee, got to discard that one, but strange i remember using that one or maybe its another lisp.
Well, for such a simple task the code can be condensed by quite a lot :D
i must be dreaming when i used that, haha, good job lee mac :D
Hehe, Cheers Wiz :P
wow very nice! :shock: both of them, gonna experiment with them abit this afternoon, though lee's seems the soundest :wink:
Thanks again guys :lol:
Z
Z
Cheers mate o:)
Z
ouch, you cut me deep shreck
Zorg, try this for an improvement :)
[i][color=#990099];; Switch/Match Text Values  by Lee McDonnell[/color][/i]
[i][color=#990099];; 09.06.2009[/color][/i]
[b][color=RED]([/color][/b][b][color=BLUE]defun[/color][/b] c:tv [b][color=RED]([/color][/b][b][color=BLUE]/[/color][/b] ent1 ent2 Str ss[b][color=RED])[/color][/b]
     [b][color=RED]([/color][/b][b][color=BLUE]and[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] ent1 [b][color=RED]([/color][/b][b][color=BLUE]car[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]nentsel[/color][/b] [b][color=#ff00ff]"\nSelect Source Text: "[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
          [b][color=RED]([/color][/b][b][color=BLUE]member[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]cdadr[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]entget[/color][/b] ent1[b][color=RED])[/color][/b][b][color=RED])[/color][/b]
                  [b][color=DARKRED]'[/color][/b][b][color=RED]([/color][/b][b][color=#ff00ff]"MTEXT"[/color][/b][b][color=#ff00ff]"TEXT"[/color][/b][b][color=#ff00ff]"ATTRIB"[/color][/b][b][color=#ff00ff]"MLEADER"[/color][/b][b][color=#ff00ff]"ATTDEF"[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
   [b][color=RED]([/color][/b][b][color=BLUE]princ[/color][/b] [b][color=#ff00ff]"\nMissed, Try Again. "[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
   [b][color=RED]([/color][/b][b][color=BLUE]progn[/color][/b]
     [b][color=RED]([/color][/b][b][color=BLUE]not[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]initget[/color][/b] [b][color=#ff00ff]"Match"[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
     [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] ent2 [b][color=RED]([/color][/b][b][color=BLUE]entsel[/color][/b] [b][color=#ff00ff]"\nSelect Text to Swap or <Match> : "[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
     [b][color=RED]([/color][/b][b][color=BLUE]cond[/color][/b] [b][color=RED]([/color][/b][b][color=RED]([/color][/b][b][color=BLUE]and[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]vl-consp[/color][/b] ent2[b][color=RED])[/color][/b]
                 [b][color=RED]([/color][/b][b][color=BLUE]member[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]cdadr[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]entget[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]car[/color][/b] ent2[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
            [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] ent2 [b][color=RED]([/color][/b][b][color=BLUE]car[/color][/b] ent2[b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=BLUE]nil[/color][/b][b][color=RED])[/color][/b]
           [b][color=RED]([/color][/b][b][color=RED]([/color][/b][b][color=BLUE]or[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]not[/color][/b] ent2[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]eq[/color][/b] [b][color=DARKRED]'[/color][/b]STR [b][color=RED]([/color][/b][b][color=BLUE]type[/color][/b] ent2[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
            [b][color=RED]([/color][/b][b][color=BLUE]if[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] ss [b][color=RED]([/color][/b][b][color=BLUE]ssget[/color][/b] [b][color=DARKRED]'[/color][/b][b][color=RED]([/color][/b][b][color=RED]([/color][/b][b][color=#009900]0[/color][/b] . [b][color=#ff00ff]"*TEXT,ATTRIB,MLEADER,ATTDEF"[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=BLUE]nil[/color][/b] [b][color=BLUE]t[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
           [b][color=RED]([/color][/b][b][color=BLUE]T[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]princ[/color][/b] [b][color=#ff00ff]"\nMissed, Try Again..."[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
 [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] Str [b][color=RED]([/color][/b][b][color=BLUE]vla-get-TextString[/color][/b]
             [b][color=RED]([/color][/b][b][color=BLUE]vlax-ename->vla-object[/color][/b] ent1[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
 [b][color=RED]([/color][/b][b][color=BLUE]cond[/color][/b] [b][color=RED]([/color][/b]ss
            [b][color=RED]([/color][/b][b][color=BLUE]lambda[/color][/b] [b][color=RED]([/color][/b]x[b][color=RED])[/color][/b]
              [b][color=RED]([/color][/b][b][color=BLUE]vla-put-TextString[/color][/b] x Str[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
                  [b][color=RED]([/color][/b][b][color=BLUE]vl-remove-if[/color][/b] [b][color=DARKRED]'[/color][/b][b][color=BLUE]listp[/color][/b]
                    [b][color=RED]([/color][/b][b][color=BLUE]mapcar[/color][/b] [b][color=DARKRED]'[/color][/b][b][color=BLUE]cadr[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]ssnamex[/color][/b] ss[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
       [b][color=RED]([/color][/b]ent2
        [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] Objlst [b][color=RED]([/color][/b][b][color=BLUE]mapcar[/color][/b] [b][color=DARKRED]'[/color][/b][b][color=BLUE]vlax-ename->vla-object[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]list[/color][/b] ent1 ent2[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
          [b][color=RED]([/color][/b][b][color=BLUE]mapcar[/color][/b] [b][color=DARKRED]'[/color][/b][b][color=BLUE]vla-get-TextString[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]reverse[/color][/b] ObjLst[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
Yours is good too Alan o:)
lol, gee, thanks.
     [b][color=RED]([/color][/b][b][color=BLUE]cond[/color][/b] [b][color=RED]([/color][/b][b][color=RED]([/color][/b][b][color=BLUE]and[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]listp[/color][/b] ent2[b][color=RED])[/color][/b]
you should replace the listp check in your cond with vl-consp. listp will return T if the variable is nil. right now, if you miss a target object, it errors out. granted, this will still switch ssget & matching if you miss a pick.
Many thanks for the tip-off Alan, I did not know that listp returned T when supplied with a nil argument.
I'll make that change :)
EDIT: Code above updated ~ thanks once again Alan for looking over it :)
Between you two, i think you could make you're own AutoCAD ;)
Thanks again guys
Z
Zorg,
No offense to the two great guys here, but this one from asmi are even better. It can cross match from dynamic block attributes to regular text too. I can not take any credit from it as it's created by ASMI.
;;  TTC.LSP - The program copies the text from: DText, MText,     ;;
;;            Tables, Dimensions, Attributes, Attributes,    ;;
;;            Attributes Definitions, DText, MText and inner    ;;
;;          block's DText and MText to: DText, MText, Tables,    ;;
;;          Attribures and Attributes Definitions. There are    ;;
;;           Multiple and Pair-wise modes.             ;;
;;  Command(s) to call: TTC                                       ;;
;;  THIS PROGRAM AND PARTS OF IT MAY REPRODUCED BY ANY METHOD    ;;
;;  ON ANY MEDIUM FOR ANY REASON. YOU CAN USE OR MODIFY THIS    ;;
;;  PROGRAM OR PARTS OF IT ABSOLUTELY FREE.                     ;;
;;  THIS PROGRAM PROVIDES THIS PROGRAM 'AS IS' WITH ALL FAULTS    ;;
;;  AND SPECIFICALLY DISCLAIMS ANY IMPLIED WARRANTY OF        ;;
;;  MERCHANTABILITY OR FITNESS FOR A PARTICULAR USE.            ;;
;;  V1.3, 29 November, 2005, Riga, Latvia                         ;;
;;  © Aleksandr Smirnov (ASMI)                              ;;
;;  For AutoCAD 2000 - 2008 (isn't tested in a next versions)    ;;
;;                             http://www.asmitools.com       ;;
(defun c:ttc (/ actDoc vlaObj sObj sText curObj oldForm
               oType oldMode conFlag errFlag *error*)
 (vl-load-com)
     (setq actDoc(vla-get-ActiveDocument
       (vlax-get-acad-object)))
         (vla-StartUndoMark actDoc)
 (defun TTC_Paste(pasteStr / nslLst vlaObj hitPt
                  hitRes Row Column)
   (setq errFlag nil)
   (if
    (setq nslLst(nentsel "\nPaste text >"))
       (cond
         ((and
            (= 4(length nslLst))
            (= "DIMENSION"(cdr(assoc 0(entget(car(last nslLst))))))
           ); end and
            (setq vlaObj(vlax-ename->vla-object
               (cdr(assoc -1(entget(car(last nslLst)))))))
          (if
            (vl-catch-all-error-p
              (vl-catch-all-apply
                'vla-put-TextOverride(list vlaObj pasteStr)))
                    (princ "\n<!> Can't paste. Object may be on locked layer <!> ")
                    (setq errFlag T)
                   ); end progn
            ); end if
          ); end condition #1
         ((and
            (= "ACAD_TABLE"(cdr(assoc 0(entget(car(last nslLst))))))
           ); end and
           (setq vlaObj
                 hitPt(vlax-3D-Point(trans(cadr nslLst)1 0))
                 hitRes(vla-HitTest vlaObj hitPt
                       (vlax-3D-Point '(0.0 0.0 1.0)) 'Row 'Column)
           ); end setq
           (if(= :vlax-true hitRes)
              (if(vl-catch-all-error-p
                   (vl-catch-all-apply
                     'vla-SetText(list vlaObj Row Column pasteStr)))
              (setq errFlag T)
              ); end progn
             ); end if
            ); end progn
           ); end if
          ); end condition # 2
         ((and
             (= "INSERT"(cdr(assoc 0(entget(car(last nslLst))))))
          ); end and
           (princ "\n<!> Can't paste to block's DText or MText <!> ")
           (setq errFlag T)
           ); end condition #3
        ((and
           (= 2(length nslLst))
           (member(cdr(assoc 0(entget(car nslLst))))
            '("TEXT" "MTEXT" "ATTRIB" "ATTDEF"))
          ); end and
        (setq vlaObj(vlax-ename->vla-object(car nslLst)))
            (vl-catch-all-apply
              'vla-put-TextString(list vlaObj pasteStr)))
              (princ "\n<!> Error. Can't pase text <!> ")
              (setq errFlag T)
            ); end progn
           ); end if
         ); end condition #4
       (T
         (princ "\n<!> Can't paste. Invalid object <!> ")
         (setq errFlag T)
        ); end condition #5
       ); end cond
             T
      ); end progn
            nil
           ); end if
    ); end of TTC_Paste
   (defun TTC_MText_Clear(Mtext / Text Str)
     (setq Text "")
     (while(/= Mtext "")
       (cond
         ((wcmatch(strcase
          (setq Str
           (substr Mtext 1 2)))"\\[\\{}`~]")
           (setq Mtext(substr Mtext 3)
              Text(strcat Text Str)
              ); end setq
          ); end condition #1
        ((wcmatch(substr Mtext 1 1) "[{}]")
         (setq Mtext
         (substr Mtext 2))
         ); end condition #2
        ((and
         (wcmatch
          (strcase
            (substr Mtext 1 2)) "\\P")
              (/=(substr Mtext 3 1) " ")
          ); end and
        (setq Mtext (substr Mtext 3)
              Text (strcat Text " ")
              ); end setq
          ); end condition #3
       ((wcmatch
          (strcase
            (substr Mtext 1 2)) "\\[LOP]")
            (setq Mtext(substr Mtext 3))
          ); end condition #4
       ((wcmatch
          (strcase
            (substr Mtext 1 2)) "\\[ACFHQTW]")
          (setq Mtext
           (substr Mtext
            (+ 2(vl-string-search ";" Mtext))))
          ); end condition #5
       ((wcmatch
          (strcase (substr Mtext 1 2)) "\\S")
            (setq Str(substr Mtext 3 (- (vl-string-search ";" Mtext) 2))
                  Text(strcat Text (vl-string-translate "#^\\" " " Str))
                  Mtext(substr Mtext (+ 4 (strlen Str)))
             ); end setq
           (print Str)
         ); end condition #6
        (T(setq Text(strcat Text(substr Mtext 1 1))
                Mtext (substr Mtext 2)
                ); end setq
        ); end condition #7
      ); end cond
    ); end while
  Text
); end of TTC_MText_Clear
 (defun TTC_Copy (/ sObj sText tType actDoc)
  (if
   (and
    (setq sObj(car(nentsel "\nCopy text... ")))
    (member(setq tType(cdr(assoc 0(entget sObj))))
    ); end and
       (vlax-get-Acad-object))
           sText(vla-get-TextString
      (vlax-ename->vla-object sObj))
     ); end setq
     (if(= tType "MTEXT")
        (setq sText(TTC_MText_Clear sText))
       ); end if
     ); end progn
    ); end if
   sText
   ); end of TTC_Copy
 (defun CCT_Str_Echo(paseStr / comStr)
   (if(< 20(strlen paseStr))
     (setq comStr
      (strcat
        (substr paseStr 1 17)"..."))
     (setq comStr paseStr)
     ); end if
    (princ(strcat "\nText = \"" comStr "\""))
   ); end of CCT_Str_Echo
   (defun *error*(msg)
   (vla-EndUndoMark
    (princ "\nQuit TTC")
   ); end of *error*
   (if(not ttc:Mode)(setq ttc:Mode "Multiple"))
    (initget "Multiple Pair-wise")
    (setq oldMode ttc:Mode
          ttc:Mode(getkword
                    (strcat "\nSpecify mode [Multiple/Pair-wise] <"ttc:Mode">: "))
          conFlag T
          paseStr ""
         ); end setq
   (if(null ttc:Mode)(setq ttc:Mode oldMode))
   (if(= ttc:Mode "Multiple")
       (if(and(setq paseStr(TTC_Copy))conFlag)
         (CCT_Str_Echo paseStr)
        (while(setq conFlag(TTC_Paste paseStr))T
           ); end while
       ); end progn
     ); end if
   ); end progn
       (while(and conFlag paseStr)
           (if(and paseStr conFlag)
               (setq errFlag T)
                 (while errFlag
               );end while
             ); end progn
           ); end if
         ); end while
       ); end progn
     ); end if
  (vla-EndUndoMark actDoc)
 ); end c:ttc
(princ "\n*** Type TTC to run text to text copy tool *** ")
