Hi...I have not done much isometric work for quite a few years now but i have a new company i am doing some freelance stuff for and the last in house person did all his drawings as isometrics. My problem is not working in isometric but when I switch to paper space..how do I convert those isometric drawings to regular 2d?...this might be basic stuff for some but like I said I havent done this in quite some time. Any suggestions?...oh..they are using AutoCadLT 2005 & Building systems MEP...I usually use AutoCad 2000 at home.
Thanks
Chris
  • Replies 23
  • tcdavis
    7
  • azzro10
    3
  • saim
    3
  • Cad64
    2
u can convert 3d objects to 2d using flatten (not sure if LT has flatten command tho)
No..just tried it. thanks though.
:unsure: Maybe I'm not understanding what you're asking? Isometric drawings are just 2D representations of 3D objects. They just give the illusion of 3 dimensions. They are already flat. Sorry, but there is no way to "convert" an isometric drawing into a plan view or elevation or whatever view you need. You just have to redraw it.
yeh iv never seen a 3d iso before so make sure u have a look in the model n change views, i think u'll be happy to discover that u already have wat ur lookin for
its when I change to paper space for printing and the original drawing is in the isometric format still...but I need it to be in the standard 2d view.
not sure i follow maybe attach some images to show wats happening
Not sure if this is what your after...
SNAPSTYL is the system variable for isoplane (0 - normal, 1-isometric), you could customize
a button with "SNAPSTYL 1 " for iso on & "0" for normal.
If it is indeed a 2D Isometric drawing then here is a semi-affective, semi-ineffective method. As previously stated, it may make more sense to just redraw.
In the attached, the layout “Front” has a viewport tweaked to allow for the orthographic projection.
UnIso.dwg
Maybe moving to 3D modelling will help.
It avoids a lot of pitfalls.
Nick
Thanks for everyones help. Unfortunatly I havent been able to resolve this. Looks like redraw will be my only option for now.
Chris
well if anyone is still interested I have figured it out inadvertantly with some help from one of the Cad tutorials...just had to go into ddvpoint and change to plan view.
Can somebody explain for the benefit of the thread how that works please?
sorry been away for a bit...yes it is available in LT...not on any drop down menu but at the command line.
  • 2 months later...
Hey Chris.
So what did you eventually do, I am finding myself in the same situation with a wiring schematic. Was drawn in 2d Isometric to represent 3d, but seems like a waste of time to redraw.
If you type in ddvpoint at the command line and then click on "set to plan view" it restores the 2d view.
  • 3 years later...
I saw someone doing the following:
- make a drawing on top view
- go to sw isometric
- export that isometric view as if it was a top-view drawing
That was awesome to pick up some architectural drawings and use them as a base for piping isometrics. Can anyone remind me HOW that is done?
