JoeC Posted June 10, 2009 Posted June 10, 2009 What hole should the adjusment pin go in when initially replacing the slave cylinder on a '76 TR6...OOPS! Sorry, wrong forum.. What is the difference in "Modify" and "Override" in the Dimension Style Manager? If I simply need to change the text height and the arrow size which should I use? Quote
dbroada Posted June 10, 2009 Posted June 10, 2009 I don't like "override". It may not still be true but you used to loose all your overrides if you modified a style leaving you with a very bitty drawing. I always use modify, and if you need variations set up a new style starting from the most recent working one. Quote
Zorg Posted June 10, 2009 Posted June 10, 2009 Modify and Dimupdate. I always stick to what i know works best, and this happens to be just that :wink: Quote
