Moving objects from one layer to another in 50+ drawings
I've been tasked with a rather large monotonous job, and was hoping someone could help me out. I need to move objects from one layer to another using some predictable conditions and don't want to spend a couple days doing it, here's the skinny.
Given an object, check to see it the layer it's on ends in -E, so for example FOO-BAR-E
In a separate template file called TEMP.DWG, check to see if a layer exists with a -N suffix, and if so move import the layer from the template and move the object to that layer, so if FOO-BAR-N is a layer in the template, bring that layer into the current drawing then move the object from FOO-BAR-E to FOO-BAR-E
If there is no layer with the -N suffix, check to see if there is a suffix-less layer in the same template file and if so, move it to that layer so FOO-BAR-E to FOO-BAR
If both those don't exist, then just move along to the next object. Rinse and repeat for the next 200 drawings.
I'm not fussy about VBA or AutoLISP, and I'm working in AutoCad 2008.
Any help would be great. :)
Everything seems do-able - but I think it would be better that you could input the layer changes into the LISP prior to running it, instead of using a Template File - switching between drawings in LISP is hard enough as it is...
Thanks Lee I'll check it out this afternoon when I get back onto that project.
The above won't work - I'll remove it and see what else I can come up with :)
Thanks Lee I gave it a try and as you said it didn't work. If I wasn't working on learning VBA for Microstation ( :( ) I'd try to whip something together this weekend but this project isn't as urgent as my others.
As always, thanks for your help and contributions to the community here.
Try this instead mate:
(I'm learning this ObjectDBX stuff, so its a bit hit and miss...)
;; ObjectDBX Tester  by Lee McDonnell (Lee Mac)
;; Credit to Tony Tanzillo for Directory Browser, Tim Willey
(defun c:MacDwg (/ refLst *error* *acad Shell fDir Dir dbx lay Tag)
 (vl-load-com)
 (setq refLst '(
                ("FOO-BAR-E" . "FOO-BAR-N")
                ("FOO-CAR-E" . "FOO-CAR-N")
 (defun *error* (e)
   (if ov (mapcar 'setvar vl ov))
   (ObjRel (list Shell dbx *acad))
   (if (not (wcmatch (strcase e) "*CANCEL*,*EXIT*"))
     (princ (strcat "\n<< Error: " e " >>")))
   (princ))
 (setq *acad (vlax-get-acad-object)
       Shell (vla-getInterfaceObject *acad "Shell.Application")
       fDir (vlax-invoke-method Shell 'BrowseForFolder
              (vla-get-HWND *acad) "Select Directory: " 0))
 (if fDir
     (setq Dir
       (vlax-get-property
         (vlax-get-property fDir 'Self) 'Path))
     (if (not (eq "\\" (substr Dir (strlen Dir))))
       (setq Dir (strcat Dir "\\")))
     (if (< (atoi (setq acVer (substr (getvar "ACADVER") 1 2))) 16)
       (setq acVer "") (setq acVer (strcat (chr 46) acVer)))
     (setq dbx (vla-getInterfaceObject
                 *acad (strcat "ObjectDBX.AxDbDocument" acVer)))
     (princ "\nProcessing...")
     (foreach dwg (setq dwLst
                    (mapcar
                      (function
                        (lambda (x)
                          (strcat Dir x)))
                      (vl-directory-files Dir "*.dwg" 1)))
       (vla-open dbx dwg)
       (vlax-for Lay (vla-get-layouts dbx)
         (vlax-for Obj (vla-get-Block lay)
           (if (setq Tag (assoc (vla-get-layer Obj) refLst))
             (vla-put-layer Obj (cdr Tag)))))
       (vla-saveas dbx dwg)
       (princ (chr 46)))
     (princ (strcat "\n<< " (rtos (length dwLst) 2 0) " Drawings Processed >>"))))
 (gc)
 (princ))
(defun ObjRel (lst)
 (mapcar
   (function
     (lambda (x)
       (if (and (eq (type x) 'VLA-OBJECT)
                (not (vlax-object-released-p x)))
         (vl-catch-all-apply
           'vlax-release-object (list x))))) lst))
Why are you learning VBA? I thought that was extinct... :P
I don't think there is a .NET API for Microstation yet. There wasn't when I last checked earlier in this year.
Bentley forums will tell us all.
Hi Mac
I have just one remark about your lisp about objectdbx
If a drawing of the directory is already open, it crashes.
One example which I used
 (defun Ouvrir_dessin_dbx(dwg / dbx doc lan rel)
   (and (setq dwg (findfile dwg))
   (vlax-for doc (vla-get-documents (vlax-get-acad-object))
     (and (eq (strcase (vla-get-fullname doc)) (strcase dwg))
       (setq dbx doc lan T)
   (and (not dbx)
     (setq dbx (vlax-create-object (if (< (setq rel (atoi (getvar "ACADVER"))) 16)
                     (strcat "ObjectDBX.AxDbDocument." (itoa rel))
     (vla-open dbx dwg)
   (list dbx lan)
An example
(Ouvrir_dessin_dbx "c:/test/11.dwg") return (# nil) --> Work with ObjectDbx
(Ouvrir_dessin_dbx "c:/test/11.dwg") return (# T) --> Work with AcadDocument
Otherwise, hats, you learn quickly
Thanks for the pointer Patrick ~ much appreciated.
I'll see about implementing that into my Attribute Extractor (in another thread).
