Hello,
Since the MText entities in AutoCAD’s VBA doesn’t support the .Explode method I’m trying to get them converted to Text type by using SendCommand – something that avoided at all in the past, so lack of clues.
Can someone tell me how to pass the current entity from a selection set to SendCommand statement?
Dim ItemsSSet As AcadSelectionSet
Dim FType(0) As Integer
Dim FData(0) As Variant
Dim theItem As Variant
FType(0) = 0
FData(0) = "MTEXT"
Set ItemsSSet = CrDrawing.SelectionSets.Add("SS1")
ItemsSSet.Select Mode:=5, FilterType:=FType, FilterData:=FData
For Each theItem In ItemsSSet
   CrDrawing.SendCommand "EXPLODE" & vbCr & [color=red][b]?????[/b][/color] & vbCr
Next theItem
Thank you!
Maybe use the insertion point of the mtext then explode using this pick point to select object ?
explode select-object enter acad
explode inspt enter vba ?
Hello,
FType(0) = 0
FData(0) = "MTEXT"
Next theItem
Thank you!
You could use
(setq sset (ssget "X" '((0 . "*TEXT"))))
(command"explode" sset"")
It may be possible to take the MText string and create a Text object and explode.
Finally,
You could create an individual text object for each char using the height of the string in the text object for offsetting
I hope one of these is useful
EDIT:
Recreate each entity delete the original and pass
 CrDrawing.SendCommand "EXPLODE" & vbCr & "(entlast)" & vbCr
Ollie.
  • 2 weeks later...
Private Function MToS(mtext As Variant) As Variant
Dim i As Integer
Dim ss As AcadSelectionSet
Dim pTexts As New Collection
ThisDrawing.ActiveSelectionSet.Clear
ThisDrawing.SendCommand "Explode" & vbCr & "(handent " & Chr(34) _
& mtext.Handle & Chr(34) & ")" & vbCr & vbCr
Set ss = ThisDrawing.ActiveSelectionSet
For i = 0 To ss.Count - 1
If UCase(ss(i).ObjectName) = "ACDBTEXT" Then pTexts.Add ss(i)
Next i
MToS = pTexts
End Function
Thank you for your solutions!
Finally have used this combination of AutoLISP statements with SendCommand – just tried to avoid doing like this. This is because I has some problems in the past when used such combination (AutoLISP routines called from VBA via SendCommand); seems that the VBA interpreter don’t wait for the AutoLISP to finish and execute next statement(s) which obstruct AutoCAD.
Regards
