AQucsaiJr Posted June 11, 2009 Posted June 11, 2009 I was just wondering if anyone knows of a LISP file that I can run that will find a Tag within a block and change the Value to whatever I want to change it to? I have a bunch of block in my drawings and I keep the Tags within them very descriptive, and somtimes I keep the Values blank or generic so I can Find a Replace throughout a drawing, but I want to get a LISP that can do this so I can use a script to run it on a bunch of drawings at a time. I don't think I can use the Find command because it will always pop-up the window to enter the text to find and replace. Quote
Biscuits Posted June 11, 2009 Posted June 11, 2009 The following will allow the user to update the revision letter in an attribute by prompting the user for the "New Revision Letter". It looks for all attribute tags named "REV" or "REV_LETTER" in all layouts. You could modify this easily for your use. Hope this helps. (defun c:UPATT (/ e ez att enn en ptcnt pscnt SSET) (SETQ ATT# (GETSTRING T "\New Revision Letter <ENTER for none>: ")) (IF (= SSET NIL) (SETQ SSET (SSGET "X" (list (CONS 0 "INSERT") (CONS 66 1) ) ) ) ) (if sset (progn (PROMPT "\nUpdating.......please wait. ") (SETQ SEL_CNT (SSLENGTH SSET)) (SETQ ATT "ATTRIB") (setq ptcnt 0 pscnt (sslength sset)) (while (< ptcnt pscnt) (if (= "INSERT" (cdr (assoc 0 (setq ez (setq e (entget (ssname sset ptcnt))))))) (progn (setq enn (cdr (car e))) (IF (= (CDR (ASSOC 66 E)) 1) (PROGN (while (= ATT "ATTRIB") (if (= "ATTRIB" (setq ATT (cdr (assoc 0 (setq e (entget (setq en (entnext (cdr (car e)))))))))) (progn (if (or (= "REV" (CDR (ASSOC 2 E )))(= "REV_LETTER" (CDR (ASSOC 2 E )))) (PROGN (SETQ ENN (CDR (CAR E))) (SETQ TSC (ASSOC 1 E)) (SETQ TT ATT#) (SETQ E (SUBST (CONS 1 TT) TSC E)) (ENTMOD E) (ENTUPD ENN) ) () ) ) () ) ) (setq ATT "ATTRIB" ptcnt (+ ptcnt 1)) ) (setq ptcnt (+ ptcnt 1) ) ) ) (setq ptcnt (+ ptcnt 1) ) ; PROGN ) ; IF INSERT ) ;WHILE ) () ) ;IF SSET AND PROGN (SETQ SSET ()) (SETVAR "HIGHLIGHT" 1) (PRINC) );defun Quote
feargt Posted June 11, 2009 Posted June 11, 2009 Have you tried using command gatte to do what you want? Quote
AQucsaiJr Posted June 11, 2009 Author Posted June 11, 2009 I have never heard of this command and can not find it in the help files... Can you tell me more about it so I can see if I can use it? Quote
AQucsaiJr Posted June 11, 2009 Author Posted June 11, 2009 No need to answer my last message... I figured it out... I believe with what I know about scripting and LISP file creation, I should be able to use this "GATTE" command to do what I would like... Thanks for the help guys. Quote
Commandobill Posted June 11, 2009 Posted June 11, 2009 Gatte isnt a command but it's actually a lisp. I believe it came in with the express tools thus not being able to find it in the help file. Quote
Commandobill Posted June 11, 2009 Posted June 11, 2009 And as this was a LISP question you may have wanted to ask it in the "AutoLISP, VBA, the CUI & Customisation" portion of this forum. Quote
AQucsaiJr Posted June 11, 2009 Author Posted June 11, 2009 Ya that's where I found the information on the GATTE was in the express help... I didn't know there was a part of the forum dedicated to such questions... I will be sure to place my future LISP questions there... Thanks for the help. Quote
blawlor Posted January 28, 2013 Posted January 28, 2013 Gatte isnt a command but it's actually a lisp. I believe it came in with the express tools thus not being able to find it in the help file. does anyone know of a lisp that will change multiple and different blocks at once. the GATTE command will only let me select one block at a time. I have a drawing full of furniture with various text attribute tags on them and i want to change them all to blank. Quote
BIGAL Posted January 29, 2013 Posted January 29, 2013 If using a lisp you can use wildcards in the block names furn1 furn2 furn* etc or you can search for multiple block names furn1,furn2,furn3. Every one will now say how will that work with different tag names pretty simple you can ignore tags and change a value by its attribute order like line1 line2 etc sane as you would see if you double click a block. This is a bit of code cut from another program under development needs the ssget added can you post block names etc maybe a dwg ; attribute change by line no (vl-load-com) (setq ss1 (car (entsel "pick block"))) (setq bname (vla-get-name(vlax-ename->vla-object SS1))) (SETQ newstrblank ".") (foreach att (vlax-invoke (vlax-ename->vla-object SS1) 'getattributes) (vla-put-textstring att newstrblank) ) (princ) Quote
