Alot of time I have to change dimension unit properties form Fractional to a 3 or 4 place decimal. The property tool pallete to annoing to me. I would like to write a routine to do this via keyboard. The problem is I can't seem to find a AutoCAD command to do this. I know I can write the lisp just don't know the command. I tryed properties, change and dimtedit. None of these are right. Can someone tell the the command name I am looking for. I can take it from there. Thanks in advance.
Check DIMVAR (Dimension Variables)
The variable is DIMLUNIT and DIMFRAC.
From the ACAD help section:
Type: Integer
Saved in: Drawing
Initial value: 2
Obsolete. Has no effect except to preserve the integrity of scripts. DIMUNIT is replaced by DIMLUNIT and DIMFRAC.
Type: Integer
Saved in: Drawing
Initial value: 2
Thanks I look everywhere including autocad help never came across this thanks again I will try them
Type: Integer
Saved in: Drawing
Initial value: 2
Those only seem to work for next time dimensions. I'm want to change a existing dimension as of now If I have a dimension on screen with fractional 1/64 precision and want to change it to decimal with .xxx precision I have to select dimension - properties (which brings up the properties tool pallete) change fractional to decimal then change .xxxxxx to .xxx precision.
I wondering if I could write a lisp that
command to3plcs
select dimensions to change
result change dimensions from fractional to a 3 places decimal
command to3plcs
Try the command Dimoverride
Also in ACAD help under commands
DIMOVERRIDE overrides dimensioning system variable settings that are associated with a dimension object but doesn't affect the current dimension style. You can also use the command to clear overrides from dimensions.
ac.mouse.gif Dimension menu: Override
ac.keyboard.gif Command line: dimoverride
Enter dimension variable name to override or [Clear overrides]: Enter the name of a dimension variable, or enter c
Dimension Variable Name to Override
Overrides the value of the dimensioning system variable you specify.
Enter new value for dimension variable : Enter a value or press ENTER
If you enter a new value, AutoCAD redisplays the Dimension Variable Name to Override prompt. If you press ENTER, AutoCAD prompts you to select the dimensions.
Select objects: Use an object selection method to select the dimensions
AutoCAD applies the overrides to the selected dimensions.
Clear Overrides
Clears any overrides on selected dimensions.
AutoCAD clears the overrides, and the dimension objects return to the settings defined by their dimension style.
Thanks for the help. I'll check out the override command but for now this is working
(defun c:to3plc ()
(setq
 OLDDIMDEC (getvar "DIMDEC")
 OLDDIMLUNIT (getvar "DIMLUNIT")
);end setq
(setvar "DIMDEC" 3)
(setvar "DIMLUNIT" 2)
(command "dim" "update" pause pause)
(command "exit")
(setvar "DIMDEC" OLDDIMDEC)
(setvar "DIMLUNIT" OLDDIMLUNIT)
);end defun
(defun c:t3 (/ OLDDIMDEC OLDDIMLUNIT)
(setq
);end setq
(setvar "DIMDEC" 3)
(command "exit")
);end defun
Problem with this on is it works fine if you select on one command. If you select more than on then dim variable do not get set back. I need it to be able to select mulitply dimension convert them to 3 plc decimal and have the dim varible be set back to what they were before exicuting the command.
try this Bradb:
(defun c:T3 (/ ss Objlst)
 (vl-load-com)
 (if (setq ss (ssget '((0 . "DIMENSION"))))
     (setq objlst
       (mapcar 'vlax-ename->vla-object
         (vl-remove-if 'listp
           (mapcar 'cadr
             (ssnamex ss)))))
     (mapcar
       (function
         (lambda (x)
           (vla-put-UnitsFormat x acDimLDecimal))) ObjLst)
     (mapcar
       (function
         (lambda (x)
           (vla-put-PrimaryUnitsPrecision x acDimPrecisionThree))) ObjLst))
   (princ "\n<< Nothing Selected >>"))
 (princ))
try this Bradb:
 (vl-load-com)
     (setq objlst
           (mapcar 'cadr
             (ssnamex ss)))))
     (mapcar
       (function
         (lambda (x)
     (mapcar
       (function
         (lambda (x)
 (princ))
Thanks Lee that works but i need more.
I do not understand visual lisp so i dont know what to edit on this lisp.
I need 3 more commands
t3m to change to 3plc and move text to outside line (DIMTMOVE 0)
tf to change to fractional (DIMLUNIT 5 DIMFRAC 1)
tfm to change to fractional and move text to outside line (DIMTMOVE 0)
Like this?
(defun c:3plc (/ ss Objlst)
 (vl-load-com)
     (setq objlst
           (mapcar 'cadr
             (ssnamex ss)))))
     (mapcar
       (function
         (lambda (x)
           (vla-put-TextMovement x acDimLineWithText))) ObjLst))
 (princ))
Or maybe:
(defun c:tfm (/ ss Objlst)
 (vl-load-com)
     (setq objlst
           (mapcar 'cadr
             (ssnamex ss)))))
     (mapcar
       (function
         (lambda (x)
           (vla-put-UnitsFormat x acDimLFractional))) ObjLst)
     (mapcar
       (function
         (lambda (x)
           (vla-put-PrimaryUnitsPrecision x acDimPrecisionFive))) ObjLst)
     (mapcar
       (function
         (lambda (x)
 (princ))
Or maybe:
 (vl-load-com)
     (setq objlst
           (mapcar 'cadr
             (ssnamex ss)))))
     (mapcar
       (function
         (lambda (x)
     (mapcar
       (function
         (lambda (x)
     (mapcar
       (function
         (lambda (x)
 (princ))
Thanks that works
I'm trying the Visiual Lisp Help Tutorials now so maybe i learn to write them on my own
