justforthis1 Posted June 11, 2009 Posted June 11, 2009 Anyone know how to make a blank line in mtext using the command line? I am using AutoCad LT 2009 i am trying to do... -mtext 1.3864,9.0665 h .06 j tc .8123,42 Line 1 Line 2 *Blank Line* Line 3 I have no idea how to make the *Blank Line* be a blank line. Any ideas? Quote
BIGAL Posted June 12, 2009 Posted June 12, 2009 You should be able to press "enter" as many times as you like? Quote
justforthis1 Posted June 12, 2009 Author Posted June 12, 2009 apparently not from the command line... from the command line if you press enter on a blank entry it exits mtext Quote
justforthis1 Posted June 15, 2009 Author Posted June 15, 2009 That works great. just noting it for anyone else that trys it you need to include the \P at the end of a line, not on its own line. i.e. Label\P (space shows here) not the following - it makes to lines with the following Label \P(space shows here) Quote
Ryder76 Posted June 15, 2009 Posted June 15, 2009 Just a bit of a drift... To have a second line of text in a dimension - type '\P' in the text override section and then add your text. Or you can type ddedit at the command line, select the dimension and the dimension text opens like an mtext editor. Quote
