flip text in Dynamic Block
Hi,
When I put a flip option on a text in Dynamic Blocks, during the flipping the text is mirrored. is there any way to preventing this?
Cheers
Ali
Is your "MIRRTEXT" system variable set to 0 if its not n set to 1 then the text will flip when its mirrored
It works.:shock:
another question,
do we have something like this for rotation?
Thanks
dont think so if u use rotate ur text will rotate too no matter what
i thought there was an option to lock text in position when creating / editting dynamic blocks ?
I guess another option is to have your text a selectable item with a rotate function. Or you can make it a visable/hidden item as well.
  • 2 years later...
For rotation, make your text move with a move parameter and command, make the move parameter a chain command (second to last line in properties), then rotate ONLY the move parameter, not the text.
  • 2 months later...
Well this was informative, and taught me other stuff that I will need to know but hasn't helped me with one particular problem; I am hoping this forum can shed some light on it for me. I am creating dynamic blocks for an electrical plan. I have been using the align command successfully for pushbutton symbols, sconces and so on. However, I have a series of blocks that include text (not attributes), like clock outlet (which essentially looks like a sconce with the letter C in it). I am trying to make a block that a) always aligns perpendicularly to whatever wall I try to place it on, and b) always maintains the text normal to the page, so that it can be read easily. I thought it would be similar to the North Arrow, but that seems to depend on the rotation action, which I am not using.
Appreciative for any input.
-Bill
a) always aligns perpendicularly to whatever wall I try to place it on.
When you insert a block I go through the right click and select my rotation to the direction of the block.
Annotative text, scaling to viewport / paperspace.
Hope that puts you in the right direction.
  • 9 months later...
I had encounter the same problem but its flip while pasting to another drawing.
what is the problem????Please help
Hi otil,
I think that azzro10 mentioned that your MIRRTEXT variable would need to be set to 1.
