NeManja Posted March 22, 2008 Share Posted March 22, 2008 Everything is writed, help pls, I need it a loot. Quote Link to comment Share on other sites More sharing options...
SEANT Posted March 22, 2008 Share Posted March 22, 2008 The only way I can do it in 2004 is via EdgeSurf as in attached. HypParabo.dwg Quote Link to comment Share on other sites More sharing options...
SEANT Posted March 22, 2008 Share Posted March 22, 2008 I guess splitting and mirroring was not needed. I wasn't sure EdgeSurf would interpolate correctly, but it seems like it does. HypParabo_SingleSurf.dwg Quote Link to comment Share on other sites More sharing options...
NeManja Posted March 22, 2008 Author Share Posted March 22, 2008 Thnx, I don't have CAD here but I'll check it tomorow. If u have some new ideas just post them. (: Quote Link to comment Share on other sites More sharing options...
thompagr Posted November 29, 2009 Share Posted November 29, 2009 thanks Seant Quote Link to comment Share on other sites More sharing options...
SEANT Posted November 29, 2009 Share Posted November 29, 2009 Hey I remember this thread. Back when I was still toiling with AutoCAD 2004. Actually, I liked that release. But, in deference to shiny new features, here’s a hyperbo-parabo AutoCAD 2009 style. This lofted surface is more easily converted to a solid, if that were a requirement. HypParabo_LoftSurf.dwg Quote Link to comment Share on other sites More sharing options...
CM Hew Posted November 30, 2009 Share Posted November 30, 2009 I have done some drawings of the hyperbolic paraboloid and also elliptical paraboloid using mesh command using calculated data fed from EXCEL in AutoCAD 2004. It this what you are looking for? 3D Equation Elliptical and Hyperbolic Paraboloid.dwg Quote Link to comment Share on other sites More sharing options...
cadcadet Posted December 12, 2011 Share Posted December 12, 2011 Is it possibleto create a hyperbolic paraboloid in revit? or dose anyone know how to convert one of these drawing into a revit file? Quote Link to comment Share on other sites More sharing options...
ReMark Posted December 12, 2011 Share Posted December 12, 2011 Revit won't open a DWG file? Quote Link to comment Share on other sites More sharing options...
ReMark Posted December 13, 2011 Share Posted December 13, 2011 Importing AutoCAD files to Revit. http://2learncad.com/blog/2010/03/importing-autocad-revit/ Quote Link to comment Share on other sites More sharing options...
cadcadet Posted December 14, 2011 Share Posted December 14, 2011 Thanks for the help on how to import it, now dose anyone know how I can turn it into a solid? I lwould like to use it as to roof of a building. Quote Link to comment Share on other sites More sharing options...
ReMark Posted December 14, 2011 Share Posted December 14, 2011 What is it now? A surface? A mesh? Quote Link to comment Share on other sites More sharing options...
dcisneros Posted January 22, 2013 Share Posted January 22, 2013 nice files. thanks! Quote Link to comment Share on other sites More sharing options...
the downing effect Posted January 23, 2013 Share Posted January 23, 2013 I have done some drawings of the hyperbolic paraboloid and also elliptical paraboloid using mesh command using calculated data fed from EXCEL in AutoCAD 2004. It this what you are looking for? That is really amazing. How did you get excel to make those shapes in Autocad? Quote Link to comment Share on other sites More sharing options...
togores Posted January 24, 2013 Share Posted January 24, 2013 Everything is writed, help pls, I need it a loot. This is something that can be done with AutoLISP. For a video class on doing this you can watch my class at Autodesk University 2012: http://au.autodesk.com/?nd=class&session_id=10671 Here are some samples: Quote Link to comment Share on other sites More sharing options...
the downing effect Posted January 25, 2013 Share Posted January 25, 2013 I will definately check out the video over the weekend, thanks Quote Link to comment Share on other sites More sharing options...
