akcowboy47 Posted June 16, 2009 Posted June 16, 2009 Hi all, Using Autocad 2007 3D: Using the view toolbar, I can select an isometric, or view from a certain side of my object. I want to create a camera with the exact same view as these pre-named views. For example, when I choose a plan view of my object, I want to set a camera that views the object from the exact same point, with the same direction, lens length etc. How on earth do I do this? It's driving me nuts! Thanks, -B Quote
papagyi Posted June 16, 2009 Posted June 16, 2009 Type in cmd for "v" or "view".Then you will see view manager dialog box and click on " new " and make view and give name as you like!Finally,you can call your save view with "view" command and set current to your save view anytime. Quote
akcowboy47 Posted June 16, 2009 Author Posted June 16, 2009 Once you create and save a view, how do you assign or create a camera with that same view? Quote
