So, some brilliant drafter that used to work here has a page full of mtext broken randomly and then split into columns. Is there an easy way to merge all the mtext into one big mtext?
Explode it all, then use the express tools tool, txt2mtxt. I don't have autocad up now so I am not sure of the exact name, type txt2 and hit tab.
it's txt2mtxt here
THANKS! i will use that next time.
and then reformat the entire thing.... bleh! It loses all it's spacing and everything. Oh well, that's the only way I know.
  • 1 month later...
you could also cut and paste
open one mtext group highlight text cut it then paste it in the first mtext
and so on...
thats what I did while waiting for a response, it took some time
it's txt2mtxt here
That is what I posted, I don't understand your post. Note that I then said type txt2 AND hit tab...
I was confirming your "so I am not sure of the exact name"
and so on...
You should "copy" and paste in the mtext you want to combine with. Then erase the text you just copied
"Cut" removes the text from the editor, but leaves you with a "null" text entity.
