Meglesniak323 Posted June 16, 2009 Posted June 16, 2009 I am using AutoCAD 2010 at home where I have been working on a school project for about 3 months. I was using 2 seperate drawing files which havent had any issues until now. It even worked yesterday. However today when I try to open these 2 files, AutoCAD starts off extremely slow and then a message pops up saying "FATAL ERROR: Unhandled Access Violation Reading Oxffffffff Exception at 63d3220eh" and then AutoCAD closes. I also tried opening my other saved AutoCAD files and it worked. The only ones that will not work are these 2 floorplans. Has anyone ever had this same problem? Quote
rkmcswain Posted June 17, 2009 Posted June 17, 2009 Sounds like the drawings are corrupt since it's only happening to these particular drawings. Have you tried opening them with the ._RECOVER command? Have you tried opening your BAK files instead? More options: http://cadpanacea.com/node/18 Quote
Tankman Posted July 3, 2009 Posted July 3, 2009 The recover command works fine when I receive drawings from another source. One client uses CADKEY, saves to *.dwg file to email at my drawing request(s). CADKEY does save to *.dwg format however, some "issues" are notable. One very notable problem is with text size. His title block and more, frequently overflow boundaries. I tried movin' them to CADKEY but, they're leary of the learning curve. Quote
