Doove Posted June 17, 2009 Posted June 17, 2009 Hi I've just modelled a building envelope and steel struture in MEP 2008, all set up with the Project Navigator. To give some idea of what is going on: Dwg A, Dwg B & Dwg C are xreffed into Dwg View. I annotate and create sections in Dwg View. I then Xref views from Dwg View into Dwg Sheet. I add my title block and rev number in Dwg Sheet. Now that the revision is issued I want to bind all xrefs and store it so I can be sure that I always have on file a copy of the rev that actually went out. When I try and bind Dwg View into Dwg Sheet then Autocad crashes - 7 times now trying it from different ways. I have run Recover on all dwgs, plus audited and purged them. Has anyone had this problem or does anyone have any suggestions on how to resolve this? Best Regards Doove Quote
