raulwg Posted March 25, 2008 Posted March 25, 2008 Hello there, does anybody know how to mirror a block containing a textfield, without mirroring this textfield? I am using Autocad LT 2008 Thanks in advance.. Raulwg Quote
raulwg Posted March 26, 2008 Author Posted March 26, 2008 Thank you for your reaction but this doesn't work for me. I had this value on 1, so I changed it. The text in the block remains mirrored, but as soon as I explode it, it reverses. Quote
Strix Posted March 27, 2008 Posted March 27, 2008 did you change this setting before or after mirroring your block? Quote
azzro10 Posted March 27, 2008 Posted March 27, 2008 the MIRRTEXT variable has no affect on blocks with standard text you'll need to make the text an attribute Quote
SLW210 Posted March 27, 2008 Posted March 27, 2008 He said textfield, I thought he meant Attribute. Like said, make it an attribute or mirror the block with _BEDIT, though if you have more than 1 insertion of the block, it will change them all, in that case you will need to rename the block. I always make text inside a block Attributes. Not sure why you need it a block but, if you make it a GROUP, the text will act normally and not mirror. Quote
Sbeth85 Posted February 13, 2014 Posted February 13, 2014 SLW210 OMG THIS IS CHANGING MY LIFE!!!! I could never figure out why my level symbols would sometimes flip the text and sometimes not... amazing!!!! thank you Quote
