JONTHEPOPE Posted June 17, 2009 Posted June 17, 2009 i get this with this code will it work with 2010? Enter chamfer distance: Specify second point: Enter chamfer angle:30 Unknown command "CHAMFER". Press F1 for help. (defun c:chamf (/ d a) (setvar "cmdecho" 0) (graphscr) (setq d (getdist "\n Enter chamfer distance:")) (setq a (getangle "\n Enter chamfer angle:")) (setvar "chamfera" d) (setvar "chamferb" (* d (/ (sin a)(cos a)))) (Command "chamfer") (setvar "cmdecho" 1) (princ) ) Quote
BlackAlnet Posted June 17, 2009 Posted June 17, 2009 What you want this lisp do? Well, i don't have autocad2010 here... but, i think this lisp does... nothing. Quote
chelsea1307 Posted June 17, 2009 Posted June 17, 2009 new to lisps, but no where do you tell it what to chamfer with what. Getting all the info about the chamfer is great but you never say whats first second angle for the chamfer just cuz you know whats supposed to go where doesnt mean the program does Quote
The Buzzard Posted June 17, 2009 Posted June 17, 2009 i get this with this code will it work with 2010?Enter chamfer distance: Specify second point: Enter chamfer angle:30 Unknown command "CHAMFER". Press F1 for help. (defun c:chamf (/ d a) (setvar "cmdecho" 0) (graphscr) (setq d (getdist "\n Enter chamfer distance:")) (setq a (getangle "\n Enter chamfer angle:")) (setvar "chamfera" d) (setvar "chamferb" (* d (/ (sin a)(cos a)))) (Command "chamfer") (setvar "cmdecho" 1) (princ) ) John I tested in 2009 and it works. Not sure if you are having a 2010 quirk, But make sure your lisp is in the ACAD Search Support Path. Good Luck, The Buzzard Quote
JONTHEPOPE Posted June 18, 2009 Author Posted June 18, 2009 I put the lisp in the support folder and the command work when i changed profiles than i change back and it stoped again ? must be profile driven but im not sure how Quote
The Buzzard Posted June 18, 2009 Posted June 18, 2009 Why don't you just put it in a folder of your choice and add that folder under Tools, Options, File tab, add the folder to the Support File Search Path. Quote
The Buzzard Posted June 18, 2009 Posted June 18, 2009 I put the lisp in the support folder and the command work when i changed profiles than i change back and it stoped again ? must be profile driven but im not sure how If you were ever to decide on upgrading your CAD version and the file was in the Support directory and you remove your old version. You would most likely lose the file if you do not remember its there. Quote
The Buzzard Posted June 18, 2009 Posted June 18, 2009 Also under Options you can set it to any Profile under the Profile tab as well. Each Profile has their specific Support File Search Path. Quote
JONTHEPOPE Posted June 19, 2009 Author Posted June 19, 2009 I'll try to restart my computer but so far no luck . I didnt have to put my folder in a support path before ? and i allways loaded just from vlisp i also have 2009 and it wont work there either i broke something for sure. is it a variable or something ? or a toggle Quote
The Buzzard Posted June 19, 2009 Posted June 19, 2009 I'll try to restart my computer but so far no luck . I didnt have to put my folder in a support path before ? and i allways loaded just from vlisp i also have 2009 and it wont work there either i broke somethingfor sure. is it a variable or something ? or a toggle Well as I said before, I tested it in 2009 and it works. Guess you will need to look elsewhere. There is nothing wrong with the program. Quote
David Bethel Posted June 19, 2009 Posted June 19, 2009 Can you try: (command "_.CHAMFER") (while (> (getvar "CMDACTIVE") 0) (command pause)) -David Quote
JONTHEPOPE Posted June 19, 2009 Author Posted June 19, 2009 I appreciate everyones help and patience. below is the reaction from code by david. I hope i dont get banned from this site for posting dumb questions. Command: *Invalid selection* Expects a point or Window/Last/Crossing/BOX/Fence/WPolygon/CPolygon/uNdo/Polyline/Distance/Angle/Tr im/Method Select first line or [uNdo/Polyline/Distance/Angle/Trim/Method/mUltiple]: *Invalid selection* Expects a point or Window/Last/Crossing/BOX/Fence/WPolygon/CPolygon Select second line or shift-select to apply corner: this is how it work with just typing it in chamfer Command: chamfer (Trim mode) Current chamfer Dist1 = 5.0000, Dist2 = 0.4374 Select first object or [undo/Polyline/Distance/Angle/Trim/mEthod/Multiple]: Command: ._chamfer (TRIM mode) Current chamfer Dist1 = 5.0000, Dist2 = 0.4374 Select first line or [undo/Polyline/Distance/Angle/Trim/mEthod/Multiple]: 56137.9840,-16170.8534,0.0000 Quote
David Bethel Posted June 20, 2009 Posted June 20, 2009 Try setting CMDECHO to 1 and see what shows up on the screen. Don't worry about asking too many legit questions, that's what this place is about. -David Quote
JONTHEPOPE Posted June 20, 2009 Author Posted June 20, 2009 (setvar “cmdecho” 1) I don't know what i would do with out all of my friends here> Quote
