AMB4311 Posted March 26, 2008 Posted March 26, 2008 I know this may be stupid but if I make a large hatched area and I want to fix it up so say I draw a big circle and hatch it. Then I want to cut part of that hatched cirlce off, can I do this without redoing the original hatch? I tried bisecting with a line then trimming but that doens't work. Is there any other way? Quote
azzro10 Posted March 26, 2008 Posted March 26, 2008 u should be able to just draw a line n trim it works every time for me just gave it a quick go to make sure, n worked like a charm Quote
Guest Alan Cullen Posted March 26, 2008 Posted March 26, 2008 If the hatch is associative to start with, you could maniplulate the original hatch boundary somehow, and the hatch will follow that manipulated boundary. P.S. Azzro's method also works. Quote
AMB4311 Posted March 26, 2008 Author Posted March 26, 2008 u should be able to just draw a line n trim it works every time for me just gave it a quick go to make sure, n worked like a charm I don't think I'm that big of a nooby but I can't figure it out I draw the line and go to do the trip, and there is nothing overlapping or anything. I am using 2008LT. Quote
azzro10 Posted March 26, 2008 Posted March 26, 2008 if the hatch isnt in a boundary, ie u draw a circle hatch it them erase the circle them it wont trim. maybe this is the problem Quote
Guest Alan Cullen Posted March 26, 2008 Posted March 26, 2008 And you should never erase the hatch boundary, bad practice. If you don't want the hatch boundary to show in plots, then stick it on a "no plot" layer, e.g. layer "hatch boundaries". Quote
makovich Posted November 10, 2008 Posted November 10, 2008 I had a drawing in which hatches would not trim. I "wblocked" the entities I was working on to a new drawing. Now trim works perfect with the hatches! It seems that sometimes a drawing can become corrupt and audit can't fix it. I hope this helps. Max Vilchez. Quote
