Jozi68 Posted June 18, 2009 Posted June 18, 2009 I am trying to select one object using vbcode. I am using this at the moment: Set objNEWSS = objDOC.SelectionSets.Add("VBA") objNEWSS.SelectOnScreen intGroupCode, varGroupValue But now my application waits for me to press enter after I've selected one or more objects. I need my application to continue the moment I click on one object. Any suggestion will be appreciated. Quote
SEANT Posted June 18, 2009 Posted June 18, 2009 Look at the ThisDrawing.Utility.GetEntity method. You will have to create your own filtering mechanism, however. GetEntity does not support groupcode filtering. Quote
Jozi68 Posted June 18, 2009 Author Posted June 18, 2009 I've heard that ThisDrawing only works in VBA. I am using VB6. Quote
Jozi68 Posted June 18, 2009 Author Posted June 18, 2009 I get this error: Object does not support this property or method Quote
SEANT Posted June 18, 2009 Posted June 18, 2009 That suck's. I no longer have access to VB6, unfortunately, else I'd take a peek. For what it's worth, VB.NET offers a lot more with regard to AutoCAD access. Quote
Jozi68 Posted June 19, 2009 Author Posted June 19, 2009 How do you recommend I start learning VB.net? Quote
SEANT Posted June 20, 2009 Posted June 20, 2009 Here is an intro video as well as a thread containing some links with useful resources. Incidentally, much of the information referencing C# is directly applicable to VB.NET. http://www.cadtutor.net/forum/showthread.php?t=28925 http://through-the-interface.typepad.com/through_the_interface/2007/11/devtv-introduct.html Quote
xsfhlzh Posted June 22, 2009 Posted June 22, 2009 try this class use SelectSingleObject function 'ClassName:TlsSelectionSet 'Writer:xsfhlzh Private oSel As AcadSelectionSet Private mFilter As New TlsResultBuffer Private sName As String Private bDeleted As Boolean Private Function IsNull() As Boolean If oSel Is Nothing Then IsNull = True ElseIf oSel.Count = 0 Then IsNull = True Else IsNull = False End If End Function Public Sub Init(Optional ByVal Name As String = "TlsSelectionSet", Optional ClearFilter As Boolean = True, Optional Deleted As Boolean = True) On Error Resume Next If ClearFilter Then mFilter.Clear bDeleted = Deleted If Not oSel Is Nothing Then oSel.Delete sName = Name ThisDrawing.SelectionSets(sName).Delete Set oSel = ThisDrawing.SelectionSets.Add(sName) End Sub Private Sub Class_Terminate() On Error Resume Next If bDeleted Then oSel.Delete End Sub Public Function ToArray() On Error Resume Next Dim i Dim objs() As AcadEntity Dim nCount As Integer nCount = oSel.Count - 1 ReDim objs(nCount) For i = 0 To nCount Set objs(i) = oSel(i) Next i ToArray = objs End Function Public Property Get Count() As Integer On Error Resume Next Count = oSel.Count End Property Public Property Get Name() As String On Error Resume Next Name = sName End Property Public Property Get Item(ByVal Index) As AcadEntity On Error Resume Next Set Item = oSel(Index) End Property Public Property Get Deleted() As Boolean Deleted = bDeleted End Property Public Property Let Deleted(ByVal Value As Boolean) bDeleted = Value End Property Public Property Get AcSet() As Variant On Error Resume Next Set AcSet = oSel End Property Public Property Set AcSet(Value As Variant) On Error Resume Next Set oSel = Value sName = oSel.Name End Property Public Sub AddItems(ByVal objs) On Error Resume Next If IsArray(objs) Then oSel.AddItems objs ElseIf IsObject(objs) Then If TypeOf objs Is AcadSelectionSet Then Dim temp As New TlsSelectionSet temp.Deleted = False temp.AcSet = objs oSel.AddItems temp.ToArray ElseIf TypeOf objs Is TlsSelectionSet Then oSel.AddItems objs.ToArray Else Dim ents(0) As AcadEntity Set ents(0) = objs oSel.AddItems ents End If End If End Sub Public Sub RemoveItems(ByVal objs) On Error Resume Next If IsArray(objs) Then oSel.RemoveItems objs ElseIf IsObject(objs) Then If TypeOf objs Is AcadSelectionSet Then Dim temp As New TlsSelectionSet temp.Deleted = False temp.AcSet = objs oSel.RemoveItems temp.ToArray ElseIf TypeOf objs Is TlsSelectionSet Then oSel.RemoveItems objs.ToArray Else Dim ents(0) As AcadEntity Set ents(0) = objs oSel.RemoveItems ents End If End If End Sub Public Sub Clear() On Error Resume Next Init sName oSel.Clear End Sub Public Sub Update() On Error Resume Next oSel.Update End Sub Public Property Get PickfirstSelectionSet() As AcadSelectionSet On Error Resume Next ThisDrawing.SelectionSets("PICKFIRST").Delete Set PickfirstSelectionSet = ThisDrawing.PickfirstSelectionSet End Property Public Property Get ActiveSelectionSet() As AcadSelectionSet On Error Resume Next ThisDrawing.SelectionSets("CURRENT").Delete Set ActiveSelectionSet = ThisDrawing.ActiveSelectionSet End Property Public Sub SelectOnScreen() On Error Resume Next If mFilter.IsNull Then oSel.SelectOnScreen Else oSel.SelectOnScreen mFilter.TypeCodes, mFilter.Datas End If End Sub Public Sub SelectSingleObject(Optional Prompt As String = "") On Error GoTo ErrHandle Dim obj As AcadEntity, pnt If mFilter.IsNull Then If Prompt = "" Then ThisDrawing.Utility.GetEntity obj, pnt Else ThisDrawing.Utility.GetEntity obj, pnt, Prompt End If AddItems obj Else SelectObject acSelectionSetAll Do If Prompt = "" Then ThisDrawing.Utility.GetEntity obj, pnt Else ThisDrawing.Utility.GetEntity obj, pnt, Prompt End If oCount = Count RemoveItems obj If oCount <> Count Then Clear AddItems obj Exit Do End If Loop End If Exit Sub ErrHandle: Clear End Sub Public Sub SelectObject(ByVal Mode As AcSelect, Optional ByVal Point1, Optional ByVal Point2) On Error Resume Next If mFilter.IsNull Then If IsMissing(Point1) Then oSel.Select Mode Else oSel.Select Mode, Point1, Point2 End If Else If IsMissing(Point1) Then oSel.Select Mode, , , mFilter.TypeCodes, mFilter.Datas Else oSel.Select Mode, Point1, Point2, mFilter.TypeCodes, mFilter.Datas End If End If End Sub Public Sub SelectAtPoint(ByVal Point) On Error Resume Next If mFilter.IsNull Then oSel.SelectAtPoint Point Else oSel.SelectAtPoint Point, mFilter.TypeCodes, mFilter.Datas End If End Sub Public Sub SelectByPolygon(ByVal Mode As AcSelect, Optional ByVal Points) On Error Resume Next If mFilter.IsNull Then oSel.SelectByPolygon Mode, Points Else oSel.SelectByPolygon Mode, Points, mFilter.TypeCodes, mFilter.Datas End If End Sub Public Property Get Filter() As TlsResultBuffer On Error Resume Next Set Filter = mFilter If Err Then Set mFilter = New TlsResultBuffer Set Filter = mFilter Err.Clear End If End Property Private Function CreatePoint(Optional ByVal x As Double = 0#, Optional ByVal y As Double = 0#, Optional ByVal Z As Double = 0#) Dim pnt(2) As Double pnt(0) = x: pnt(1) = y: pnt(2) = Z CreatePoint = pnt End Function Quote
xsfhlzh Posted June 22, 2009 Posted June 22, 2009 'ClassName:TlsResultBuffer 'Writer:xsfhlzh Private m_TypeCodes, m_Datas Private m_Count As Integer Public Sub SetData(ParamArray Values()) On Error Resume Next Dim i Dim n As Integer Dim nCount As Integer nCount = (UBound(Values) + 1) / 2 - 1 If nCount = 0 And IsArray(Values(0)) And IsArray(Values(1)) Then m_TypeCodes = Values(0) m_Datas = Values(1) Else Dim t() As Integer, d() ReDim t(nCount), d(nCount) For i = 0 To nCount n = i * 2 t(i) = Values(n) d(i) = Values(n + 1) Next i m_TypeCodes = t m_Datas = d End If m_Count = UBound(m_TypeCodes) + 1 End Sub Public Sub AppendData(ParamArray Values()) On Error Resume Next Dim m As Integer, n As Integer, nCount As Integer nCount = (UBound(Values) + 1) / 2 n = m_Count + nCount - 1 ReDim Preserve m_TypeCodes(n), m_Datas(n) For i = 0 To nCount - 1 m = m_Count + i n = i * 2 m_TypeCodes(m) = Values(n) m_Datas(m) = Values(n + 1) Next i m_Count = m_Count + nCount End Sub Public Sub GetData(ByRef TypeCodes, ByRef Datas) TypeCodes = m_TypeCodes Datas = m_Datas End Sub Public Sub Clear() m_TypeCodes = Null m_Datas = Null End Sub Public Property Get TypeCodes() As Variant TypeCodes = m_TypeCodes End Property Public Property Let TypeCodes(ByVal vNewValue As Variant) m_TypeCodes = vNewValue End Property Public Property Get Datas() As Variant Datas = m_Datas End Property Public Property Let Datas(ByVal vNewValue As Variant) m_Datas = vNewValue End Property Public Property Get Count() As Integer On Error Resume Next Count = m_Count End Property Public Property Get IsNull() As Boolean IsNull = (Count = 0) End Property Quote
Jozi68 Posted June 30, 2009 Author Posted June 30, 2009 Thanx for your reply xsfhlzh. Unfortunately I can not use ThisDrawing as I am using VB6. Looks like I will have to start learning .net Quote
Jozi68 Posted July 23, 2009 Author Posted July 23, 2009 OK so now I'm using vb.net. xsfhlzh, I don't really know what to do with all the code you sent me. I just need a user to select a single polyline before my program continues. Quote
SEANT Posted July 23, 2009 Posted July 23, 2009 Post #12 of this thread has an example of a selection filtered for just a Polyline. http://www.cadtutor.net/forum/showthread.php?t=29602 Quote
bhargav1987 Posted April 27, 2010 Posted April 27, 2010 I am trying to select one object using vbcode. I am using this at the moment: Set objNEWSS = objDOC.SelectionSets.Add("VBA") objNEWSS.SelectOnScreen intGroupCode, varGroupValue But now my application waits for me to press enter after I've selected one or more objects. I need my application to continue the moment I click on one object. Any suggestion will be appreciated. Is there any possibility to find an nearest line from a point using vba?? Quote
