I m very new to AutoCAD VBA, although I have some knowlege of programming in VB 6.0 and know AutoCAD well enough. Is it possible to do 'measure' command using AutoCAD VBA.
You should be able to acces any autocad command
ThisDrawing.SendCommand "measure" & vbCr
If you know pick point and distance then add to above with & vbCr
It would probably be better though to have a look here for numerous examples of "measuring" (distance along pline) as more than likely you will want something smarter and more complex at a later date.
Hi Bigal, I searched for a few codes that sounded similar to 'measure'. I think I would need this kind of a code as given below:
(defun div-error (msg)
(if
(vl-position
msg
'("console break"
"Function cancelled"
"quit / exit abort"
(princ "Error!")
(princ msg)
(while (> (getvar "cmdactive") 0) (command))
(command "._undo" "_end")
(command "._u")
(setq *error* olderror)
(defun divplus (len segm / num lst)
(setq num (fix (/ len segm)))
(setq cnt 0)
(while (<= cnt num)
(setq tmp (* cnt segm))
(setq lst (append lst (list tmp)))
(setq cnt (1+ cnt))
(setq delta (- len (last lst)))
(if (/= delta 0.)
(setq lst (append lst (list (+ (last lst) delta))))
lst
(defun divminus (len segm / lst)
(while (>= len 0.)
(setq lst (append lst (list len)))
(setq len (- len segm))
(if (not (zerop (last lst)))
(setq lst (append lst (list 0.0)))
lst
(vl-load-com)
(prompt "\n *** Type D50 to execute *** \n")
(defun C:d50 (/ *error* acsp adoc ang appd cnt
div-error head len olderror pl
pt pt_list rad step st_list st_num st_txt
tht util
(or adoc
(setq adoc
(vla-get-activedocument
(vlax-get-acad-object)
(or appd (setq appd (vla-get-application adoc)))
(or acsp
(setq acsp
(vla-get-block
(vla-get-activelayout adoc)
(or util (setq util (vla-get-utility adoc)))
(command "._undo" "_mark")
(setq olderror *error*)
(setq *error* div-error)
(setq step 50.
head "10+";(getstring T "\nEnter label prefix<10+> :")
tht 2.5;(getreal "\nEnter text height<3.6> :")
rad 1.;(getreal "\nCircle radius <1.2> :")
(vla-getentity
util
'pl
'pt
"\nSelect line NEAR OF LINE START to labeling: >>> \n"
(if pl
(setq len (vlax-curve-getdistatparam
pl
(vlax-curve-getendparam pl)
(if (< (distance (vlax-safearray->list pt)
(vlax-curve-getstartpoint pl)
(vlax-curve-getendpoint pl)
(setq pt_list (divplus len step))
(setq pt_list (divminus len step))
(setq
pt_list (vl-remove-if
(function not)
(mapcar (function (lambda (x)
(vlax-curve-getpointatdist pl x)
pt_list
(setq ang (angle (car pt_list)(cadr pt_list))
ang
(cond ((< (/ pi 2) ang (* pi 1.5))(+ pi ang))
(T ang)))
(setq cnt -1)
(repeat (length pt_list)
(setq cnt (1+ cnt))
(setq st_num
(cond ((< cnt 10) (strcat head "0" (itoa cnt)))
(T (strcat head (itoa cnt)))
(setq st_list (cons st_num st_list))
(setq st_list (reverse st_list))
;; following delete if not needs >>>
(vla-addcircle acsp (vlax-3d-point x) rad)
pt_list
); <<< by suit
(mapcar
(function
(lambda (x y)
(setq st_txt (vla-addtext acsp x (vlax-3d-point y) tht))
(vlax-put-property st_txt 'Rotation ang)
(vla-update st_txt); <<< by suit
(vlax-release-object st_txt)
st_list
pt_list
(if (not (vlax-object-released-p pl))
(vlax-release-object pl)
(princ "\nNothing selected try again\n")
(vla-zoomextents appd)
(vla-regen adoc acactiveviewport)
div-error nil
;;;TesT:
;;;(repeat 8 (C:d50))
vBulletin® v3.6.12, Copyright ©2000-2009, Jelsoft Enterprises Ltd.
(while (>= len 0.)
lst
(vl-load-com)
tht util
(or adoc
(setq adoc
(or acsp
(setq acsp
(vla-get-block
(setq step 50.
(vla-getentity
util
'pl
'pt
(if pl
pl
(setq
(function not)
pt_list
ang
(T ang)))
(setq cnt -1)
(setq cnt (1+ cnt))
(setq st_num
pt_list
); <<< by suit
(mapcar
(function
(lambda (x y)
st_list
pt_list
div-error nil
;;;TesT:
But, I would need it in VB because Lisp is absolutely Latin to me and I need to modify the above code slightly. Is it possible to do this kind of a thing (as the code above) in VB. Any help would be highly appreicated
Ryan
Check the recent posts here for "points on a polyline" "divide polyline" words to that effect there are a lot of examples here doing different things both vba and lisp also "batter" I got a program from here calculates points along a pline.
Hey Thanks Bigal, I tried to search according to the keywords you suggested and I came across one of your codes:
http://www.cadtutor.net/forum/showthread.php?t=28376
From this what I can understand is, it retrieves all the coordinates of the polyline and the interval decides the no. of blocks that would be inserted inside each segment.
Can i modify this code as to use it just like measure command. Where all, will i need to modify.
and one more thing, how did you decide those constant values for startang and endang?
Thanks a lot !!
Ryan
