Matho Posted March 27, 2008 Posted March 27, 2008 Hi all How do I make text flow around a circle/arc? I know there is a command but i'm not having much luck finding it. Thanks once again Refer Eg. Quote
Matho Posted March 27, 2008 Author Posted March 27, 2008 Found it in express tools. It's all good now Express>Text>Arc-Aligned Text Quote
MisterJingles Posted April 30, 2009 Posted April 30, 2009 I dont see this on Autocad 2007 LT. Is there a different command for this function here? Quote
avieira Posted April 30, 2009 Posted April 30, 2009 in 2008 it works fine it here : Express>Text>Arc-Aligned Text Quote
ReMark Posted April 30, 2009 Posted April 30, 2009 LT does not have Express Tools and, more importantly, without an add-on program such as AutoCAD LT Toolbox, it does not have the ability to use Lisp routines. But all is not lost. Here are two suggestions. Over in the AutoDesk Discussion Groups frequent contributor Dean Saadallah offered this suggestion. "DIVIDE or MEASURE command, use a block consisting of a letters, explode and edit afterwards." It is by no means an elegant fix but it would do in a pinch. The other answer might be found by searching for a Diesel routine written by Robert Freeman for AutoCAD LT called Text on Arc. I have no direct experience with the loading of Diesel routines nor with this particular routine but I recommend you research it a little further and determine whether or not it will suit your needs. Quote
Tankman Posted May 1, 2009 Posted May 1, 2009 LT doesn't have Express Tools; Arc Aligned Text. Like Dean, and ReMark quoted, "Explode and edit (rotate), as required." Quote
avieira Posted May 6, 2009 Posted May 6, 2009 Hello all here goes the 2nd part iu have the drawing all doen , but i see that the to arcs an boths sides look wrong,, how do i fix it so they look similiar or porportion to the center ones,- Quote
avieira Posted May 6, 2009 Posted May 6, 2009 Hello all here goes the 2nd part i have the drawing all done , but i see that the to arcs an boths sides look wrong,, how do i fix it so they look similar or proportion to the center ones,- http://i155.photobucket.com/albums/s298/macussa/fgh.jpg Quote
chelsea1307 Posted May 7, 2009 Posted May 7, 2009 your more likely to get your second part answered if you start a new thread Quote
