Rsblades Posted June 18, 2009 Posted June 18, 2009 Hey everyone, I just installed Autocad 2010 Imperial (Vault Edition) as well as 2 other of my office mates. We are all having the same error when we try to load our routines. here is the error: Command: appload Protools2007.lsp successfully loaded. Command: Regenerating layout. Regenerating model. ; error: ARXLOAD failed It successfully loads the lisp file but when you hit the ok button the "; error: ARXLOAD failed" shows up. This is only happening with this one lisp file does anyone know what the problem is? thanks in advance, Ryan Quote
Rsblades Posted June 19, 2009 Author Posted June 19, 2009 Hey everyone, I just installed Autocad 2010 Imperial (Vault Edition) as well as 2 other of my office mates. We are all having the same error when we try to load our routines. here is the error: Command: appload Protools2007.lsp successfully loaded. Command: Regenerating layout. Regenerating model. ; error: ARXLOAD failed It successfully loads the lisp file but when you hit the ok button the "; error: ARXLOAD failed" shows up. This is only happening with this one lisp file does anyone know what the problem is? thanks in advance, Ryan I just tried uninstalling and reinstalling 2010 and the default profile (C3D_Imperial) wont even load right.. it loads with a blank screen, no menu no ribbon no toolbars, nothing. i cant even right click in an empty drawing. LAME. however, i can type "options" and my saved profile loads just fine but then i cant use any of the ACAD commands except options, load, save, all the basic commands however i cant use appload or anything, i get an unknown command error any help is appreciated. Quote
Rsblades Posted June 19, 2009 Author Posted June 19, 2009 I know there is a category for this thread but i need help with it and no one seems to get on the "error messages" category so im hoping someone in here will be able to help me out. heres the link to the thread with my problem: http://www.cadtutor.net/forum/showthread.php?p=247263#post247263 thank you, Ryan Quote
Cad64 Posted June 19, 2009 Posted June 19, 2009 Threads merged. Please don't cross post. The reason you're having problems with the arx error is most likely because you are trying to run a lisp routine that was written for 2007. 2010 has a different file format, so that routine is probably not compatible. Quote
Rsblades Posted June 19, 2009 Author Posted June 19, 2009 My apologies. How then would i re-write the lisp for 2010. the lisp routine worked through 2009. Threads merged. Please don't cross post. The reason you're having problems with the arx error is most likely because you are trying to run a lisp routine that was written for 2007. 2010 has a different file format, so that routine is probably not compatible. Quote
