Everyone who has to draw lots of Survey Plans, CP, DP, RP has their different methods of efficiency. I'm sick of typing @,
(defun C:BD  (/ LEN DEGS MINS SECS)
(command "_.line" (getpoint "\nPick a starting point: ")
;And Copy this bit 100 times or so as necessary*******
        (strcat "@" (rtos (getreal "\nType Length: ")) "<"
       (if (= (setq DEGS (getstring "\nType Degrees: ")) "") "0" DEGS) "d"
       (if (= (setq MINS (getstring "\nType Minutes: ")) "") "0" MINS) "'"
       (if (= (setq SECS (getstring "\nType Seconds: ")) "") "0" SECS) "\""
(princ))
Now this works fine, the code just doesn't look nice.
I've tried putting a while loop around the bit I copy 100 times:
(Setq zzz 0)
    (while (/= zzz 3)
      (setq zzz (+ zzz 1)))
But then the 'line' command doesn't draw each line as I go, in fact it doesn't seem to do anything. Can while loops be placed inside of a line command?
Any help would be appreciated.
Try this buddy:
(defun c:test (/ pt len deg mIs Sec Ang)
 (if (setq pt (getpoint "\nSelect Starting Point: "))
     (command "_.line" "_non" pt)
     (while
       (and
         (not (initget 2))
         (setq len (getdist pt "\nSpecify Length: "))
         (or (setq deg (getreal "\nDegrees: ")) (setq deg 0.))
         (or (setq mIs (getreal "\nMinutes: ")) (setq mIs 0.))
         (or (setq Sec (getreal "\nSeconds: ")) (setq Sec 0.))
         (setq Ang (* pi (/ (+ deg (/ mIs 60.) (/ Sec 3600.)) 180.))
               pt (polar pt Ang len)))
       (command "_non" pt))
     (command "")))
 (princ))
No problem - if you need the any part of the code explained, just shout :)
Yes I'll have to dwell on the code for a few hours first before I have code questions :-)
An immediate question I have is, I usually have 0 degrees facing up the page but this code outputs it to the right. Where is this set in the code and can I change it?
And what does the _non do?
Ta.
I have merely converted the Degree/Min/Sec angle into Radians, and just used the Polar function to plot the point. So, if you want 0 Degrees to be Vertical - just shift all measurements by (pi/2) rads (90 degs).
     (while
       (and
         (not (initget 2))
         [color=Red][b](setq Ang (* pi (/ (+ deg (/ mIs 60.) (/ Sec 3600.)) 180.))[/b][/color]
               pt (polar pt [color=Blue][b](+ Ang (/ pi 2.))[/b][/color] len)))
     (command "")))
 (princ))
Disregards OSNAPS, so that the plotted points are accurate.
Thanks again. That _non is handy as I was getting a few zero length lines before.
I should have asked this along with the 0degrees facing north question; Polar computes anti-clockwise, can it be made to compute clockwise? I thought maybe *-1 but that doesn't work...
Edit: I'm glad you didn't stay up :), -1 does work:
               pt (polar pt (+ (* Ang -1.) (/ pi 2.)) len)))
Thanks for your help Lee
Would this not work?
     (while
       (and
         (not (initget 2))
               pt (polar pt (+ (* -1. Ang) (/ pi 2.)) len)))
     (command "")))
 (princ))
Edit, nice one mate.
As another option look at ACAD system variables AngBase and AngDir
Those variables do look like a better alternative to "- pi/2" & "*-1". Just not too sure how to implement them.
An aside: Lee I've had a good look at your code and I think it all makes sense! As for writing it myself...
Just out of interest, regarding the code I initially posted, it seems to me it's not possible to run a while loop without running another command (eg the polar command). Is this true?
Nice Idea CAB - hadn't thought of that.
You can have a while with just a test statment, for example, observe the following code (best example I could think of):
[b][color=RED]([/color][/b][b][color=BLUE]defun[/color][/b] c:test [b][color=RED]([/color][/b][b][color=BLUE]/[/color][/b] ans[b][color=RED])[/color][/b]
 [b][color=RED]([/color][/b][b][color=BLUE]while[/color][/b]
   [b][color=RED]([/color][/b][b][color=BLUE]progn[/color][/b]
     [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] ans
       [b][color=RED]([/color][/b][b][color=BLUE]cond[/color][/b]
         [b][color=RED]([/color][/b][b][color=RED]([/color][/b][b][color=BLUE]getint[/color][/b] [b][color=#ff00ff]"\nType an Even Number <10> : "[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
         [b][color=RED]([/color][/b][b][color=#009900]10[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
     [b][color=RED]([/color][/b][b][color=BLUE]if[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]not[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]zerop[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]rem[/color][/b] ans [b][color=#009900]2[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
       [b][color=RED]([/color][/b][b][color=BLUE]not[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]prompt[/color][/b] [b][color=#ff00ff]"\nYou Typed an Odd Number!"[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [i][color=#990099]; Stay in Loop[/color][/i]
       [b][color=BLUE]nil[/color][/b][b][color=RED])[/color][/b] [i][color=#990099]; Else Exit Loop[/color][/i]
   [b][color=RED])[/color][/b] [i][color=#990099]; End Progn[/color][/i]
 [b][color=RED])[/color][/b] [i][color=#990099]; End While[/color][/i]
 [b][color=RED]([/color][/b][b][color=BLUE]alert[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]itoa[/color][/b] ans[b][color=RED])[/color][/b][b][color=RED])[/color][/b]
 [b][color=RED]([/color][/b][b][color=BLUE]princ[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
Notice that the WHILE statement only includes a test statement, which, if returns nil, will exit the loop.
A variation on Lee's routine:
(defun c:test (/ pt pt1 len deg mIs Sec Ang)
     (while
       (and
         (not (initget 2))
         ;;  calc new point based on AngBase 90 & AngDir 1=Clockwise
               pt1 (polar pt (+ (* -1. Ang) (/ pi 2.)) len))
      (entmake
        (list (cons 0 "LINE")
              (cons 10 pt)
              (cons 11 pt1)
      (setq pt pt1)
Thanks to you both.
Aside: That "Lisp Logic and More" tut is pretty good.
Well I got heaps more lisp questions but they're really not to do with drawing survey plans so I'll ask them in another thread; This ones' solved.
Thanks to you both.
Ask away Steve, we'd be happy to explain :)
